OK, back on topic! - I have a dual mono Buff II in pre-order and I have a few questions:
1) Any suggestions for "stacking" these modules using high quality "plug" connectors rather than wires? Digital signal input, Volumite (I2C) and output stage?
2) What is the current draw of the IVY III positive and negative rails?
3) What is the current draw of Buff II @ 5V?
Thanks,
Nic
Thanks,
Nic
well the molex connectors are pretty good and i'm sure they have some pin headers that would suit, but finding the right ones amongst the literally thousands of parts they have is daunting to say the least. I would be interested in these as well if you find the part numbers. low impedance copper pin headers = win over wires or connectors anyday i'm in agreement there
I can highly recommend the ethercon line for i2s, (sorry brian, last i'll say)
so this is all getting rather interesting. now looking into a suitable battery supply circuit. thinking i'll just use a modified version of the tangent PPAv2 battery supply, rail splitter/vground circuit with some SMD super regulators. using the neutrik minicon connectors for the headphone connection. as a rule Ihavent liked the neutrik stuff too much in the past, but the upper end of their stuff and purpose built things like ethercon, powercon and minicon are all really nicely made products. the minicon is superb and very well built. so much more suitable for a balanced headphone connector than 3 or 4 pin XLR IMO.
there will be some worried high end producers out there at the moment, the pricing of this setup brings what can reasonably be called high end to the grasp of people that may not have been able to afford it before.
The IVY BOM on the web site now lists the headers I will be supplying for stacking the Buffalo on the IVY. With the supplied .625" standoffs, they fit perfectly. Both header and connector are gold plated for reliable mechanical contacts.
I meant to measure this before shipping all my protos off to Russ the other day, but my brains are spilling out on the floor at the moment and I forgot. He will be able post the numbers the final IVY numbers in a day or two.
Pull down resistor value
Really looking forward to receiving my Buffalo II next month.
In the mean time I gathering/resurrecting my I/V options. Can you tell me the value of the "pull down" resistors?
I am planning to try a transformer conversion, a Welborne Cato set-up, a Borbely board if I can reserrect 24V supplies and a Lampizator V out.
Thanks for providing such a great experimental platform.
Best
Bob
Best
Bob
Thanks,
Nic
1) The connector Brian has selected for the kits is excellent.
2) An IVY III does About ~90ma per rail. If you set the Placid BP for 150ma you will be in great shape.
3) I would run ~5.5V(but not over). About ~290ma I would set the placid for about 350-400ma.
Cheers!
Russ
If I recall right this is a bit more than B32S. Is this with the dual AVcc shunts installed?3) I would run ~5.5V(but not over). About ~290ma I would set the placid for about 350-400ma.
Thanks,
Nic
Thanks,
Nic
Yes, that's with the AVCC shunts. They consume about 50ma per side. So 100ma.
Hi Russ
So 90mA per rail in total But how much current will each rail of each of the three sections of IVY III draw (with a 15/0/-15V supply)? I.e. L, R, and ballsie?
Paul
About 35ma per side and about 20ma for the bal/se per rail.
BUF II dual mono.
Here is a diagram of the balanced dual mono output configuration.
Cheers!
Russ View attachment 159883
Cheers!
Does the diagram imply that half the dacs of one ESS are in anti-phase mode?
It does indeed.
- More Vendors...
- Twisted Pear
- Buffalo II
