BTSB Buffer - SE/Bal to SE/Bal Buffer GB
I tried, but failed, to order the Compact All SMT Bare PCB. Your etsy shop responds with an error message because there is no Through Hole option selected. When I select one Bare PCB in each category I get 1 PCB each in the cart for USD23 total.
Founder of XSA-Labs
Joined 2012
Here is the schematic and BOM for the compact SMT version.
attachment.php
  • BTSB_SMT_v1_BOM.zip
Hi X again =),
BTSB buffer looks very nice, however I have to make my own PCB where I am going to use THAT 1646. But when I look on your design I don't understand one thing.
Is R17 and C23 connected only with H2 in SMT version? Because in TH version it is connected with XLR connectors and H2, is it right? If yes, what is different in terms of input?
Sincerely
Petr Petlach
Founder of XSA-Labs
Joined 2012
For TH or SMT version, if you want to drive it with SE input, you need to connect the +ve input to the signal and -ve input to ground. This can be achieved using an XLR combo input jack like the one in the BOM of the TH version and use a 1/4in mono TS plug such that the "ring" and the "sleeve" are grounded to each other and the "tip" goes to +ve input. They make RCA female to 1/4in TS plugs, they are very handy.
Here is what I use:
Amazon.com: Hosa GPR-101 RCA to 1/4 inch TS Adaptors (2 pieces), Black: Musical Instruments
Founder of XSA-Labs
Joined 2012
Measurements of BTSB
This was a lot of work, but in the end - worth it to prove to myself that the BTSB is a superb buffer. I setup the TPA3255 to be powered from a 12v lead acid battery driving an 800w DC-DC converter (51v). The battery also provides the 12v to power the BTSB DC input. The 1kHz low noise Victor's oscillator is also powered by 4x9v batteries. Laptop (HP Core i7 Pavillion) was powered by its own battery and laptop USB powers the Focusrite. This was the best way to get myself off the dirty nasty grid around my house. Just touching the ground/earth mains gives ugly noise in the measurement. Here is a photo of the setup:
attachment.php
A closeup of the BTSB, amp and DCDC:
attachment.php
Here is the FFT for BTSB connected to the Focusrite's XLR input (instrument mode impedance - high impedance) and the BTSB was set to 20dB gain and putting out 2.0Vrms. The level of disortion here (0.00034%THD) is probably the Focusrite's internal distortion as we are already below the device's published ratings:
attachment.php
Here is the FFT for the BTSB in SE to Bal driving the TPA3255 with PFFB and at the reference 10Vrms into 10ohm condition. It is getting 0.0012% THD, well below the TI factory spec for the same reference condition with their own PFFB implementation. It is about the same as the previous 0.0011% THD that I measured using the THAT1646 SE to Bal converter. However, the noise profile now is cleaner with less HF "grass". The amps are different units so there is some variability to be expected. The previous one tested has been sold:
attachment.php
For completeness, here is what the BTSB powered with a cheap 12v 1A SMPS wallwart - it adds a little more noise at 60/120/180Hz, but still a respectable noise floor and THD and harmonic profile stays the same:
attachment.php
So I think we can see that this design is excellent and does what it is supposedd to do - not add any noise or distortion to the signal.
Hello xrk971, i look forward to receiving your board. For the components (TH Board), i should follow the BOM list in the zip file attached in the #1 post. Is that correct?
For SE at input, simply connect +IN to signal and -IN to circuit ground?
