The schematic on Radiomuseum.org is for the tube version only. Does anyone have the FET version?
I noticed there's a quick disconnect connector on one of the wires that may be associated with the 200v polarization voltage. Does anyone know the purpose of this? Is there a reason to disconnect the polarization voltage for some microphones that can be used with the 2203? Or is this some kind of test mode?
Not all mics require the voltage. I found both versions when I looked!
HI chaps,
I wonder if any of you ever got hold of service information for that B+K 2203 Sound level meter?
I have contacted B+K this week and they no longer support this model , neither do they have any remaining service data for it...:-(
The serial number of my instrument is 887512 making it a later NON thermionic tube/valve input device.
Looking inside the pcb's are littered with silicon transistors and a couple of what look like op-amps.
Can anyone supply me with the correct service data for this model please?
Thanks in anticipation
Dave
Dave
love to have a copy
Hi Dave, I would be very pleased to have one
Adrian
I now have a free copy of the B+K 2203 service manual in .pdf format if anyone is still looking for it!
Dave
Adrian
Also love to get a copy
Hi Dave,
I would greatly appreciate a copy of the 2203 service manual. My meter just died and I've been searching everywhere for a service manual.
2203's above sn598006 are quite different from earlier models, 1/2" mic socket, fet input and ICs replace discrete components.
All the components in mine seem fine except for one IC I can't identify, an AD3226.
Murray
Hi Dave,
Murray
Does anyone know if the ZC0009 microphone preamp is interchangable with other preamps, like 2619/2639? So, can I use this with other instruments, like 2607 etc?
Sorry, I mean ZC0007!
- Design & Build
- Equipment & Tools
- Bruel & Kjaer 2203 service manual
