You know, I see this word "short" all the time. What does "short" mean? Are we talking millimeters or feet? I have some earth wiring that's at least 20cm, and I have no problems. What am I risking with such a long run?Nuuk said:Keep all wiring as short as possible.
Dave
Nuuk,
This was just a test case is just test wiring just to make sure everything was going to work. On Friday I get out of school for 2.5 weeks and was planning on making very short wiring and a good box, but I guess I needed to make a more perminant box with shorter connections to start with.
Due to my box design which I thought was going to be good to decrease itnerference turned out not to great because I was un aware of AC and DC voltages crossing and creating interference.
The box that it was in, I think would be much better for an amp without volume controls due to the RCA wires right above the amps but not too spead apart that you have to seperate a nice pair of RCA wires, and the speaker outs were very close.
But I'm going to work on a better design considdering I do need a pot.
Good luck with the kit.
Kneadle,
My "short wires" for example my speaker out are about 3cm. I think If you can keep most wires less than 20cm is pretty good.
Kneadle,
