break subwoofer
i recently broke open my friends harmon kardon subwoofer(it came with his HP comp)
i want to make an amplifier for my ipod
The woofer has a rating of 12 V, 1A which i can achieve
there is an IC - BA5417 inside , it is a dual power amplifier
DATA SHEET : http://kitsrus.com/pdf/ba5417.pdf
I would like to know a schematic to use this IC for the above application one exists in the datasheet on pg. 4
but i'm not sure if it is workable
Also what sort of power consumption will this thing have
PLEASE HELP I'M A BIT NEW TO THE AUDIO PART OF ELECTRONICS :confused:
here is the cct diagram how should i give input, the symbols are a bit odd.
the o/p from my ipod will mean one ground termiinal and the two audio channels where will each of these wires go in the beneath given cct
also how do i introduce volume control to the circuit
please help
power amplifier IC
i have attached the cct diagram i found about this IC BA5417
it is a power amplifier
as one can see pins 11 & 12 are input but how exactly does on give this input
i plan to give input from my ipod so there will be one ground wire and the two audio channels , where exactly do these three wires need to go
also how can i introduce volume control to the cct.
lastly the datasheet of the IC is at :
http://www.ortodoxism.ro/datasheets/rohm/ba5417.pdf
i just cant figure out what current will be needed i plan to supply 12 V (from 8 AA battery) but how much current??
Just for background this amplifier will give output to a speaker the whole project is for making a portable speker for my discman
PLEASE HELP
:headbash:
