Braun AM-FM Receiver Model R4 - Questions arround MCU
This model with Class-H output power stage was released in two versions.
1) The old R4-version (rev.1) uses follow MCU device:
Sampo (made by Hitachi) VSI86009 - "HD-614080S-A89" (HD614080SA89).
This must actually be a custom made part, because there are not to find a datasheet.
2) The second version (R4/2 resp. R4 rev.2, also last version at the same time - so I think) uses follow MCU part from Hitachi:
Hitachi HD4074008S, Sanyo-Fisher Item-No 4091266802
This must actually be not custom made and a good available part, because there are genuine Hitachi datasheets - go to
http://www.dzjsw.com/jcdl/h/HD4074008.pdf
HD4074008S pdf, HD4074008S description, HD4074008S datasheets, HD4074008S view ::: ALLDATASHEET :::
HD4074008S HITACHI, HD4074008S Datasheet
Additional this type No is mentioned in the book
"The CB PLL Data Book" - for cover image go to
The CB PLL Data Book - Franklin, Lou
and to page 36 and 57 about
The CB Pll Data Book - Lou Franklin - Google Books
If URL don't goes open, try by google the keywords "The CB PLL Data Book" and "HD4074008".
This means, this IC must be in use in several devices like car radios, CB transmitter/receiver and various HiFi systems from the low cost range.
Who can find out, in which models this MCU is in use?
Images of both MCU types you will find in the last two attached pics - found about
http://www.braun-hifi-forum.de/viewtopic.php?t=600
Schematic you will find there:
http://elektrotanya.com/braun_r4_sch.pdf/download.html
Thank you for advices.
P.S. Who can upload a Service Manual?
