Box for dynaudio 17w 75 XL
GM
Joined 2003
'Ideal' is a variable depending on the needs of the app, but its published specs are OK for a TL, especially if driven with a high output impedance to raise its effective Qts; otherwise, a MLTL is probably the best overall compromise.
These are old drivers though, so unless you measure them, no telling how accurate a cab alignment will be. Anyway, download these into WinISD Pro alpha's driver folder to view/experiment with different alignments and/or load them into a TL/horn program: Downloadable WinISD Pro Files - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
GM
Basstuba
Hello,
i made a bass horn with dynaudio,
6 dB crossover. around 1991
