Boston gt24
If i pull the rectifiers out amp powers up and idles fine. And doesnt go into protection with the rectifiers out
With the rectifiers in the circuit, does it attempt to draw excessive current or do you read any excessive DC offset on either channel (measured directly on the speaker terminals for each channel)?
Have your scope probe on the bridging terminal of each channel and watch for a pulse of DC as the amp tries to power up?
It doesnt draw excessive current. With power ,ground,remote hooked up no DC on outputs.
IF i put my meter leads on the left channel and then apply remote voltage it has 12volts of dc on outputs for 2 to 3 secs the goes back to 0 volts. I also checked the left channel with my scope and it has dc upon power up for a few sec's
