BOSOZ PSU problem
I'm in the process of building a Bosoz, but I have a problem
when testing the PSU.
The fuse blows out when I plug the PSU (I used 1 amp then 1.6 amp
fuse).
All connections are ok.
The schema is the same as original, the only thing i changed
was the bridge, i used fast diods instead.
I used 2 15k resistors on V+ and V- as advised in N. Pass article
for testing.
Transformers are 2 toroïdal transformers
2x30 each to get 1x60 (120 VA)
I join a picture of the PSU.
Thank you for your help.
thank you Alain for your answer but i checked
of course the wiring of everyhing, mainly of the bridge,
and i was not much concerned about that since
i always use that kind of bridge with fast recovery diods
and coupling capacitors
on all PSU i build and i never had problems like this one.
All worked perfectly.
I'm still trying to find out why it does not work.
Bye
how about the transformer wiring? you might want to check with them not connected to the psu. Do the fuses blow without the psu connected? do you get 60 volts across each pair of secondaries?
how about the polarity of the zeners? Condition of the pass transistors? are they in the rght spot with proper orientation? filter caps OK?
I think I have made all of the above mistakes a few times. :cannotbe: good luck
thank you for your answer
BobEllis: i checked everything, everything is ok
Kilowattski: i do use a slow blow fuse
So I still don't understand such a current surge at start, able to
blow a 1.6 A fuse ! This is the first time it happens to me .
As i'm not so familiar with regulation with zener diods, if i can't
find the reason why of this problem, maybe i will make a
typical regulation with lm317,lm337 instead, this always works.
Unless somebody can help me...
Thank you for your answers.
I finally solved the problem by putting a 10 OHMS thermistor
between the mains and the phase of each primary winding.
I've been testing the psu for about an hour end everything
seems to be fine, the fuse does not blow out.
I still do not know why this happened before as there were no
mention of thermistors in Nelson Pass article for inrush current.
Moreoever i could find on the posts people having the same
problem, so i was a bit confused...
I hope this will help anyone having the same problem if it occurs.
