Re: BoSoZ & Aleph caps- need help
For my Aleph 5 I used for C6 - 680pF MKT(Wima), for C7 - 0.047uF MKP(Wima), for C8 - 10pF silvermica and for BOSOZ I allready have MKP10(Wima).
best regards,
LEON
xsnailx said:i am asking for advice
iam about to buy caps for my aleph 5 / bosoz project
so i need some suggestions what is being used for:
in aleph 5
C6-680pF
C7-.047uF
C8-10pF
in bosoz
C3,C4 10 uF
mica / mkt / mkp or maybe something else
best regards,
LEON
czesc xsnailx!!!
tez jestem z polski i z tego co wiem to w ofercie TME
www.tme.pl mozna kupic elementy oferowane przez Farenell
wystarczy odpalic katalog on-line farnella wpisac 10p znalezc w odpowiedziach glimm...costam kondensator - masz numer w katalogu farnel>> teraz w katalogu tme wpisz far i bez spacji numer z katalogu farnell i masz cene. o ile pamietam to 10p mikowy jest za jakies 6zl.
pozdrawiam.
pozdrawiam.
Can you order at Farnell.com ?
I got the 10 uF caps for the BoSoZ and the silver-mica 's (Aleph5) from them. They also have all the special resistors.
Good luck on your hunt for all the parts. Watch your wallet... it's empty before you know it
But i think it's worth the money.
Gr,
Nick
Gr,
Nick
No problemo!!!
Mia³em zamiar zbudowaæ Citation12 zmodyfikowany przez NP, jednak udalo mi sie zalatwic calkiem spore radiatory i koncenruje sie na postawieniu PushPull Follower w klasie A wg. projektu Pavla Macury:
http://www.pha.inecnet.cz/macura/next.htm
Powodzenia!!!
Pozdrawiam.
Powodzenia!!!
Pozdrawiam.
okay let's talk in english then...or you can mail me if there is a need
the heatsinks, well it's quite a problem here in poland - yesterday I got a reply from company:
http://www.hydrogig.dos.pl/index.html
they can cut any lenght you want and quite cheap!!!
I ordered at once and waiting for their answer or arrival of the stuff
As far as I know they are the cheapest in our country.
by the way - my name is marcin.
regards
regards
marcin, aren't they the same ?
http://www.hutnik.com.pl/alu010.html
looks very similar?
by the way what brand of electrolytics did you prefer
looks very similar?
yes - exactly the same. if you have possibility to buy in Hutnik then go for it - it will propably be even cheaper!!!
The brand of electrolitycs - in power supply I'm going to use computer grade caps by Kendeil.
In the circuit just low ESR Phillips/BC Components - maybe in future upgrade to Panasonic FC - but to buy them cheap in Poland is a dream right now
for the testing stage it's good to use cheaper stuff like low ESR by Hitano or sth
- that's how I see it...anyway I'm no specialist in this matter
greets
greets
for me to go to hutnik is no problem because it is only 20 kilometers more
i live in cieszyn so http://www.hydrogig.dos.pl/ - they reside in bielsko and hutnik is in kety
but another problem arises hehe
i need a faceplate for my amp so i need 10 mm alu plate and it icannot be bought in hutnik nor in hydrogig
do you know any good source?
ESR Phillips/BC Components - did tou buy them in tme?
Panasonic FC where did you spotted them ? www.madral.pl? akkus?
the BC Components from TME.
the panasonic FC at madral - I didn't see any FC at akkus.
the faceplate is another problem - I didn't found so far any good supplier wit 10mm thick alu. In worst case I will try sth else or thinner alu sheet.
What brand of cans are U going to put into your PS??? - any good source?
greets!
greets!
i found an aluminium dealer in ostrava
www.alufinal.sk
they webpage states that they have even 100 mm plates i will send them an email and check
for my psu i will use kendail cans
you can obtain them at http://www.farad.kutno.pl/
www.alufinal.sk
I was going to buy Kendeil cans at:
http://www.infoelektronika.com.pl/sklep.php
- do You know anything about prices at FARAD, are the K05 cheaper there???
Give me a note if You know more about those alu from Ostrava pls.
Greets!
Greets!
i send an email to farrad so iam waiting for response but friend of mine bought
6x47000/63V for 80 zł / szt
iam investigating czech aluminium suppiles so i will drop you a note what i have found
if you are intrested in buing at farrad we may buy together and get a lower price maybe
this is good idea xsnailx!!!
Of course if it's possible - I was going to have 4x22000/40V for my PS, snap-in types. I know there is the problem with mounting them, but they are a lot cheaper comparing to screw terminals.
This or other way FARAD is way cheaper than my source, so I'm for that solution.
- BoSoZ & Aleph caps- need help
