Oh god i feel stupid >.<
So the idea i had from the begining is the best?
But if so, will this do it? http://www.clasohlson.se/Product/Product.aspx?id=161192396
EDIT:
Just realised my coaxials stick out 75mm and not 100mm as i thought.
25mm x 2 = 50mm and just checked, that's enough to the magnets not pulling each other away too much
So don't think i will need those things
But is there anything else that could make the boombox better?
Im starting building it on wednesday so after that, its too late
EDIT:
I am almost done soldering, but i dont have any more solder :/
Going to buy a 250mA fuse, a fuse for when im running it on higher power(how much A do i need? im going to use both a 12v system and a 24v system, perhaps 6A?),
more solder and a heatsink
Also, im looking for a very cheap pre-amp.
Would this one work? $13.80 - Digital Audio MP3 Player Module with Remote Controller (1.5" LCD) - DIY Parts & Components
Will it work to plug in the speaker outputs to my amp input?
Will it be more than 12V output?
If so, will it work to put a resistor to make it 5V?
I think the amp max input should be at 5V, not sure.
