Hi JPV
Well, maybe my Google-power is weak today but I didn't find anything. Can you give me a link? Would be very grateful if you can send scans. If you need my email address it is on the home page of my website at:
douglas-self.com
If you google J.K. Roberge you will come to a place where you can download parts of the book. If you cannot find the book, you can download what is already provided on Roberge/MIT site. I can try to scan the missing chapters and send it to you. There should be no copyright problems because it seems that the book is public domain now.
JPV
douglas-self.com
Hi JPV
douglas-self.com
Have a look here;
OP2E
Haven't tried to download it myself, so can't comment on status of the link on the page.
Sandy
That works nicely, thank you very much indeed.
For those downloading, be aware that only Chapter 1 and Chapter 13 of the Roberge book are in the PDF. But Ch 13 is all about compensation; I have just skimmed it and it looks like excellent stuff, going deeper than most texts I have seen.
Thanks again
Thanks again
I sent you an email.
This book is the best I have read. Chapter four is about compensation and chapter 13 is compensation revisited.
There is a chapter called an illustrative design that goes through a full discrete ( bjt/fet) opamp design with in depth compensation analysis, a gem.
At the same level but very recent, broader and more advanced, the book of W.Sansen 'Analog design essential' is unmatched.
JPV
Hi Doug,
I agree. The output stage is the main nemesis and is usually the most expensive one to improve (in terms of dollars, heat and size). Making an IPS-VAS that is superb is much less expensive by comparison. That is why I'm inclined to favor TMC over TPC. However, implicit in my leaning is the sense that TMC does more to improve the output stage than TPC for equal margin in the amplifier against any sort of instability. Whether my sense of that is correct in light of a rigorous exploration is unclear.
Bob
Actually TMC gives almost exactly the same net loop gain about the output stage as the equivalent TPC while delivering a single-pole loop gain response for the input stage. This makes TMC pointless relative to TPC.
Not at all...
Things are a little more subtile..
Actually, TMC has intrinsically more total available NFB than TPC....
http://www.diyaudio.com/forums/soli...ells-power-amplifier-book-98.html#post2398684
Hi Mike,
Where is Edmond when we need him to defend TMC?
Anyway, it probably depends on your definition of what consitutes TMC that is equivalent to TPC. Maybe you can tell us and also show some simulation that supports your assertion. My inclination is that it is wrong to say that TMC is pointless relative to TPC.
Bob
Not at all...
Wrong.
Wrong.
I did provide a valuable explanation to back my sayings.
One more time, the VAS has inherently more gain in a
TMC configuration than in an equivalent TPC one,
due to heavier VAS loading of the latter..
You don t agree with that?...Surprising...
Seems that you didn t catch the curves meaning..
Edit : I repost the sims.
The red curve is the OLG of an uncompensated amp.
Green is OLG of the amp with influence of TMC vas loading.
Blue is the same amp OLG with influence of TPC VAS loading..
These curves talk by themselves, so please, no more "wrong"
as you re only making fool of yourself with such unsubstancied claims...
wrong?
Hi Bob,
Why should I respond to someones mono syllabic barking anyhow?
Besides, that person is on my ignore list.
Edmond.
Hi Mike,
[snip]
Bob
Hi Bob,
Edmond.
Hi wahab, interesting curves, could you explain how you got them (Schematic, method, loop breaking point, etc...)? A LF loop gain of about 132dB and a unity loop gain frequency of 40MHz makes me believe there's a possible mis-alignment in the analysis methodology.
I myself don't believe TMC is creating extra loop gain, but rather using the same loop gain available in TPC to (mostly) linearize the output stage and (less) to linearize the VAS. Ingenious, but the end result, from a linearizing perspective, is exactly the same. Actually I think TMC could be worse than TPC, if the VAS and the input stage are incompetently designed.
I am wondering if TMC provides any pole splitting effect; I guess so, but to a lesser degree, because of the lower loop gain available around the VAS. I wish I had a quantitative evaluation of all these...
Hi, YWN
True that i was laconic about the sims protocols.
The red curve is obtained by breaking the NFB loop
with a high value inductance and removing the compensation
network, and as, we have the "brut" OLG of the amp.
No wonder in these condition that the unity gain bandwith
extend to 40mhz or so.
Green and blue curves are obtained by connecting the TMC/TPC networks
as they should be, safe that the cap that feed the VAS input
is connected to ground rather than to the vas input.
Of course, in normal operation, seen from the star point,
this cap is connected to a -180° source rather than to earth,
increasing the vas loading to an equivalent doubled capacitance,
but the effect of connecting to earth is little and will not provide
a false advantage when TMC is compared to the same TPC network,
since for the test of this one, the same cap is also connected to earth,
so the eventual errors are only in absolute value and are of the same
order with the two compensation networks, leading to a right relative
comparison.
As you surely noticed, we then obtain the OLG of the amp BEFORE
compensation is implemented but with the VAS loaded by its respective
compensation networks.
As can be seen, the difference between TMC and TPC is due only
to the latters heavier VAS loading.
What remains of the OLG, after the VAS loading is counted can
be used in many way, wether splitted between TMC local NFB
and the amp global NFB, or used almost entirely as global NFB by
implementing TPC, but this latter will forcibly have a slightly lower OLG
to start with , on the order of 15db in the curves i posted,
and at frequencies that are largely in the audio band.
Hi YWN
Syn08 has done a very good analysis of TMC and TPC here
Read from post #63
Too bad that he don’t post here anymore, but I see that you are quite up to date YWN so maybe you could ask him if he allows you to post his analysis with the attachments at this forum?
Cheers
S
Hi YWN
Read from post #63
Cheers
S
A very good analysis, indeed.
Thanks for bringing theses clues.
Though, i don t agree with a little part of his conclusion,
when he states this :
"Bottom line, I think this analysis shows the ultimate TPC and TMC equivalence; TMC has, from a loop gain perspective, absolutely no advantage over TPC; it just a simple and clever way to split the loop gain across the VAS and OPS. The equivalent loop gain is identical"
As discussed in this thread, it appears that they are not
equivalent, in respect of LG ,at least in my understanding..
Hi Stein & Wahab,
Her analysis contains an error, see: http://www.diyaudio.com/forums/soli...erview-negative-feedback-326.html#post2382015 , Mystifying TMC.
E.
Hi Mike,
Bob
Same component values for both is what i mean.
Bob, see below:
http://www.diyaudio.com/forums/solid-state/94676-bob-cordell-interview-negative-feedback-308.html#post2365966
That conclusion is 100% correct.
It would be correct if the VAS loading of the relevant compensation
networks was not existent or equivalent, but since it exist and is not
equivalent, and is easily measurable, this conclusion is wrong and
you are wrong as well.
I will mention that i used the same components values
for TPC and TMC sims, so that only aggravate your lack of clues
about what is discussed..
Unless trolling is the only thing you re interested in ?...
Who knows...
Hi wahab, I am still very uncomfortable with 130dB of loop gain and 40MHz of unity loop gain frequency, these values are out of any scale for an audio amp, at least according to the definition of "loop gain" I was taught. Could you please post a schematic with the relevant component values and the loop gain probe in place? Perhaps you are testing the Miller loop only? But even so, 40MHz unity loop gain frequency would be outlandish.
- Bob Cordell's Power amplifier book
