I thought about building a jig which did that. Grounded emitter amplifier loaded by triple cascode current source whose Zout >>> amplifier transistor's ro. Measure the gain, divide by gm, presto you get ro. Then solve for Early Voltage VA from the Ohm's Law equationI would like some comments from anyone on the approach of determining VAF by the use of small-signal 1kHz ac Zout measurements at a nominal typical operating point.
- (VA + Vce) = ro * Ice
If Ice = 1mA and Vce = 5V and VA=1000V then gain= 38400 and ro= 1 Megohm. To measure VA within 1% you need the bias circuit's input impedance to be > 100 Megohms. Yuck! At 1 kHz, the impedance of a 1.6 picofarad capacitor is 100 Megohms.
So I stuck with (low duty cycle pulsed) DC measurements. I'll let someone else be the hero who measures VA using AC techniques at 1 kHz.
(Oh by the way, measure the Early Voltage "VA" of the NPN transistor MJE340. You'll find its VA exceeds 1000 volts. Yes really. VA=1000 is not an unrealistic exaggeration.)
Bob, I always thought Early effect was sorta 'linear' ... unlike the truly EVIL variation of Cob, often the biggest THD culprit for THD20k.Secondly, the Early effect in reality can be nonlinear and a function of the operating current of the transistor.
Is there a good accurate explanation of Early non-linearity on the web?
Gotta be unnerstanabel to sum 1 hu neber wen 2 skul
Hawksford certainly showed the dynamic distortion importance: https://web.archive.org/web/2013012..._lab/malcolmspubdocs/J10 Enhanced cascode.pdf
even if the "base current canceling" circuits are much older
I used the name "super-pair" from a '60 circuits reference book and attributed it to Baxandall - turns out the refernces I found weren't complete - the circuit goes back even further
and we've discussed it, related issues several times here at diyAudio
http://www.diyaudio.com/forums/solid-state/25172-baxandall-super-pair.html
Here is the "350" from 3 different manufacturers and in both SMD (MJD) and thru-hole (MJE) packages. Hover over the image to read the device type, embedded in the filename. Not a lot of variability among them.
I'm definitely going to have to get my Locky curve tracer up and going.
Bob
I thought about building a jig which did that. Grounded emitter amplifier loaded by triple cascode current source whose Zout >>> amplifier transistor's ro. Measure the gain, divide by gm, presto you get ro. Then solve for Early Voltage VA from the Ohm's Law equationThe problem is biasing: how do you set Vce accurately? (Ice is easy, it's just the triple cascode's output which you can measure with a DVM). In particular, how do you set Vce accurately without having the bias mechanism load down the ultra high impedance collector node?
These are all good points. Observing the hi-Z node is the trickiest part, as you observe. Let's assume for the moment that we observe it with a JFET op amp connected as a unity-gain buffer. We'll assume that the Vce voltage is held within the available input range of the op amp. We then use the output of the op amp to feed a DC servo circuit that biases the base of the DUT. A control voltage applied to the servo integrator sets Vce. The servo must have very high attenuation at the test frequency so as not to cause any shunt feedback impedance-reducing effect.
The ac test signal is then applied to the hi-z node through a 1 Meg resistor. Ro at the hi-z node is then inferred from the amount of signal attenuation through the 1 Meg resistor. Attenuation of 0.5 would imply Ro = 1 Meg. In this approach the transistor is not connected as an amplifier whose gain is measured. It is really a current source doing a balancing act with the current source load.
A variant of the approach would be to hold the hi-z node at zero volts and set Vce by adjusting the value of the negative rail. In this arrangement, the negative rail must be very well bypassed to ground so that its impedance to ground at the test frequency is << re' of the DUT.
I'm guessing 10% accuracy is enough for the purposes here.
Bob
Gotta be unnerstanabel to sum 1 hu neber wen 2 skul![]()
I have not seen a good explanation of it either. The Early voltage can have a dependence (sometimes mild) on Vce and/or Ic. This can be influenced by things like doping profile and emitter crowding effects and dependence of beta on Ic. The biggest cause of finite Early voltage is thinning of the effective base region by depletion region expansion as Vcb increases. I am not a device person, of course, and others I'm sure can explain the effects much better than I can.
Bob
Bob
Supreme and Pisces are available from Stanford they are very powerful device modelers, there's probably a huge learning curve.
Stanford University TCAD Tools
Myself, I'm a fan of ultra-symmetry subtract like from like in all possible cases, which on some circuits involved tied off unused transistors just to match the non-linear capacitances.
It is finished, I just got home from my last official day as a full time employee. I don't know about other's out there but I was sort of ambivalent at the end but I did make a point of turning out the lights something I have not done for decades.
CONGRATULATIONS!!!
I'm sure you will keep busy in retirement, and that helps a lot with the ambivalence. Put the old day job in the rear-view mirror!
Bob
Bob
Very few saw it likely because there is no trivial description of the phenomena involved with the nonlinear Early effect. Wambacq and Sansen has the whole derivation and explanation (below is only a fragment):
https://books.google.ca/books?id=Fb...#v=onepage&q="early effect" nonlinear&f=false
Bob
The last time I tried my Locky curve tracer it ate my transistor.
I haven't used it since.
Observing the hi-Z node is the trickiest part, ... assume for the moment that we observe it with a JFET op amp connected as a unity-gain buffer. ...a DC servo circuit that biases the base of the DUT.
The PNP transistors I measured, had a 21-to-1 spread of Early voltage*: the lowest was 21X smaller than the highest. If you then include a 10-to-1 range of collector currents at which you plan to measure Early voltage, that becomes a total range of collector impedance of 210-to-1. You might need more than one test jig, each jig with a different value of injection resistor, for best signal-to-noise during measurement.
*preliminary datasampling suggests that NPNs will turn out to have a wider spread (maxVA / minVA) than PNPs.
Mr. C.
it seems several boyz are interested in your Hafler DH 200C , over at tweak thread
http://www.diyaudio.com/forums/solid-state/31131-hafler-dh-200-220-mods-26.html#post4924742
I think it would help them if you just post sch file , to save them staring at ootoobe video and drawing schmtc that way
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
Pimm did elebroate ss ccs for tubez
the Hawksford paper I linked to above does OK eplaining if not giving prior art
there you should see that Cob isn't the limit with the cascode "done right"
For me it was the commute home at the end of the final day: less joyful and more bittersweet than I expected. Congratulations!
Thanks, the fact that I have agreed to come in on a two hr. a week basis to help out probably has tempered my feelings. I keep my badge, computer, access to our simuators, email, and of course all my friends.
Thanks for this Waly.Very few saw it likely because there is no trivial description of the phenomena involved with the nonlinear Early effect. Wambacq and Sansen has the whole derivation and explanation (below is only a fragment):
I've developed a headache trying to unnderstan the excerpts but took away from p187
That's sorta my understanding of the subject ...It is seen that the Early effect is in fact "quite linear"
So my question to yus gurus is whether LTspice & the Cordell et al models sim whatever 'non-linearlity' remains of this.
- Bob Cordell's Power amplifier book
