Hi Bob/John/Nelson
I don't know whether you are taking aim at someone who only uses simulation ...
a good guide is "if the computer says something won't work, it is probably right. If the computer says it will work, you check it"
... but from my point of view you need the simulations to confirm that low distortion is possible. If the simulation shows high distortion, it's likely to be right.
cheers
John
I have to smile if someone
quotes parts-per-million distortion figures from a simulation.
cheers
John
john_ellis said:If the simulation shows high distortion, it's likely to be right.
Quite true, but I don't recall any post where someone was
bragging about parts per hundred...
Ever drive a 924 or a 944? That was essentially what I was referring to. Why quibble? Learn and grow! For the record, I owned and drove a Renault Dauphine approximately 95,000 miles in 5 years and I know its characteristics well. I have also owned a Porsche 924 and currently own a 944. I know their driving characterisics just as well.
Nelson Pass said:[snip]You may have been there at AES when Lipshitz and Van der Kooy
presented their (masterful) analysis on the Quad current dumping
amplifier. When asked by a member of the audience how it
sounded, one of them said (and I paraphrase here), "I don't
know, we didn't listen to it."
Nelson,
I share your irritation. We all know that listening tests have nothing to do with a technical analysis. Yet there is always a misguided fellow human being that asks the most irrelevant question for the context...
Kudo's for whoever gave the answer for not letting himself being drawn out and giving the reasonable answer.
Jan Didden
I am trying to make a comparison between indifferent phono design and excellent phono design by using autos as a comparison. The name Porsche is written on both the 924 and 944 in prominent letters and they were at least 'set up' by Porsche at the factory to be able to go into a controlled drift with a competent driver at the wheel.
The Renault would actually roll over, if you got into a tight spot, rather than drift. That is a serious design difference. When I switched over to Pirelli tires on the Renault, it too could be put into a controlled drift as they would break away into a drift, before the Renault started to think about rolling over.
The best phono design, in my opinion, requires that you accept what is actually being developed by the phono cartridge in reasonable worst-case conditions and design the phono stage to not clip, slew rate limit, or even significantly distort during cartridge mistracking.
Bob appears to ignore mistrackiing as a design reference. That is the difference in our positions.
Hi Nelson
... but if you were aiming for 1ppm and the simulation said 10 ppm, it is still probably right. ...
... though at some point the simulations will reach the 0/0 problem ...
cheers
John
cheers
John
john_ellis said:... but if you were aiming for 1ppm and the simulation said 10 ppm, it is still probably right. ...
Of course perfect algorithms and megabit precision will not
help when models which are only approximations. And then
when I see the 10 and 20% variations in actual active parts, I
don't expect high precision except as an abstraction.
Hi Tim__x,
I am a firm believer. This from years of empirical evidence working on countless amps. They actually sound smoother if you match the LTP carefully as opposed to throwing in a pair of transistors.
Isn't it great when a sim can validate real life findings?
-Chris
Absolutely!The 34db difference does show the need for balanced circuits to be intentionally imbalanced in simulation.
-Chris
S-K Filter Simulation and Monte Carlo
Nelson,
I have seen the same behavior in simulations and believe it has to do with the phenomena occurring at the onset of oscillation. In order for oscillation to start the simulator may need to provide a "kick" to push the system under consideration off a local minimum. One simple workaround is to intentionally introduce a small amount of random noise or a noise pulse.
We have also seen the converse of this problem, where an amplifier will apear stable under quiescent conditions but will oscillate when presented with certain input signal conditions.
I am glad to see that someone has finally mentioned MC techniques. It is probably the only feasible way to guarantee proper circuit behavior over the range of voltage, temperature, and manufacturing variations. this becomes even more the case when large numbers of input conditions must be comprehended
One extension to MC that we have found particularly useful is Design of Experiment (DOE). This technique constructs a mult-dimensional curve that fits data points taken on each simulation run and then uses a curve fitting algorithm to construct a multi-dimensional response surface. Once this surface has been defined it is possible to estimate output results for any set of inputs that lie within the bounds of the response surface. The DOE tool also generates parametric sensitivity curves, so one can determine sensitivity of each input parameter. We use the JMP(R) tool where I work, but do not know what the cost of the tool is or whether lower cost alternatives are available.
Nelson,
the range of -50db (the worst) to -81db (the beat) shows that some imbalanced parameters have less effect than others.
Did you keep a note of which parameter variations gave the poorest results?
The simulation varied all parameters simultaneously through fifty different iteration, I didn't isolate individual parameters. It was basically a sim of fifty unmatched randomly selected transistor pairs.
When you were varying all those parameters by +/- 20%, were the two collector currents kept identical? I'm usually under the impression that, because of the nature of the exponential Vbe characteristic, matching the collector currents is pretty much the most important thing in a diff pair, and am also under the impression that if the collector currents are matched, they are pretty tolerant of some other mismatches in parameters. What did you find?
Yes, I did keep Ic matched, I forgot to mention I also used a extremely low frequency dc servo made from a voltage controlled current source and a ridiculously large capacitor.
Yes, I was asking. The cross quad looks odd to me, and I have
yet to wrap my head around it.
I only very recently grasped it (and probably not completely, just intuitively), I'll see how well I can describe its operation later.
Bob Cordell said:
BTW, have you used the ON ThermalTrak devices yet? Even as a transistor apart from the thermal tracking diode, they look better overall than the Sanken RETs. Don't go by what it says in the spec sheet table; look at the actual typical beta vs IC curves and the ft vs IC curves.
I've given the Sanken parts the skip in favour of the non-ThermalTrack version of those devices for my latest design for nearly all the reasons you just listed.
Glen
darkfenriz said:Ring emitters rule!
To be honest, the only real way to know for sure would be to build two identical output stages/amplifiers - one using the Sanken parts and one using the Onsemi parts.
I'm taking a punt with the Onsemi parts though. At the end of the day, I really don't think there would be all that much in it, either way.
But don't be fooled by the 200W NPN Sanken 60MHz fT spec.
Glen
- Bob Cordell Interview: BJT vs. MOSFET
