anli said:Alex,
Thanks! It would be interesting to estimate a minimal Id when the effect may be neglected.
Absolutely! In this respect pseudo-A class operation for AB, when devices are conducting all the time is very attractive and, obviously, there is no such problem in class A .
Alex
Aha, I'm at right wayx-pro said:Absolutely! In this respect pseudo-A class operation for AB, when devices are conducting all the time is very attractive and, obviously, there is no such problem in class A .
Alex
I've posted my measurement results of Cgs for a couple of MOSFETs in a new thread:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=100550
Alex
Alex
Alex
I've been using this approach for over 2 years:
http://www.diyaudio.com/forums/showthread.php?postid=562708#post562708
http://www.diyaudio.com/forums/showthread.php?postid=980998#post980998
Rodolfo
Well done, Rodolfo! Now you know why it could be so important
Cheers
Alex
Cheers
Alex
A word of clarification nonetheless. I do not consider myself qualified to side on the current discussion regarding Cgs (and others) variability.
What I became aware then was about the serious problem posed by the FET input capacitance during crossover, if Vgs is allowed to drop to 0 during the non conducting half cycle in class B/AB.
Next best in my mind was to arrange Vgs to never drop below Vth.
Rodolfo
It is a good point. My measurements are not enough to make correct conclusions anyway. It only serves the point of a possible problem with an input capacitance interpretation in a standard model, as in this particular experiment the capacitance in a real device and in a model behave differently
ingrast said:What I became aware then was about the serious problem posed by the FET input capacitance during crossover, if Vgs is allowed to drop to 0 during the non conducting half cycle in class B/AB.
A possible reason for it that there is essentially a wasted charge, which is considerably larger than one required to operate the device in a linear region.
ingrast said:Next best in my mind was to arrange Vgs to never drop below Vth.
Rodolfo
And that looks like a good solution for class AB.
Cheers
Alex
Rodolfo
Hi Rodolfo,
You really should have a look at:
"Audio power with a new loop", Marcel van de Gevel, EW, Feb., 1996, pp.140-143
It does exactly that!
estuart said:
Hi Rodolfo,
Thanks Edmond, I was no aware about this reference, could you provide a link or a copy to check?
Rodolfo
estuart said:
Hi Glen,
In stead of TMC, you might consider NDFL, but, combined with a complementary VAS, it's probably difficult to implement.
Regards, Edmond.
Hi Glen,
I've figured out to do this and I've broken the 1ppm barrier.
Some results:
Vo = 19.5Vpp into 4 Ohm -> THD20 = 3ppm W/O TMC
THD20 = 0.8 ppm with TMC.
Also,I solved the problem of the "fighting VAS's", as described by Bob Cordell, see:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=94676&perpage=10&pagenumber=15 post #145
I you're interested, I'll post a preliminary schematic.
Cheers, Edmond.
ingrast said:Thanks Edmond, I was no aware about this reference, could you provide a link or a copy to check?
Rodolfo
Hi Rodolfo,
I've only a paper copy, no scanner and no link, sorry.
Maybe someone else on the forum does have a digital copy. So folks, please do help Rodolfo.
Without any results in a couple of days, please remind me and I'll digitize it on a scanner of one of my friends.
estuart said:
Hi Rodolfo,
Don't worry Edmond, on the other hand, if you can do a quick sketch of the arrangement as in a simulator, it could be enough to evaluate.
Thanks again, Rodolfo
ingrast said:Don't worry Edmond, on the other hand, if you can do a quick sketch of the arrangement as in a simulator, it could be enough to evaluate.
Hi Rodlfo,
See below. This scheme is based on a non-linear common-mode control loop, which is also applicable to BJT's , common source/emitter or common drain/collector topologies.
PS: Please. don't ask me why Marcel has added Q8.
Probably, this design is slightly simpler and has the same aim:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=99313
x-pro said:I've posted my measurement results of Cgs for a couple of MOSFETs in a new thread:
Alex
Hi Alex,
I've been following this discussion between you and Andy with great interest. You've both made some very good points. I've looked at the measurements you posted for the ZTX part and I think you may have inadvertantly confirmed some of what Andy has been saying, but I'm not sure. My bottom line suspicion is that you are both still talking about operation in two different regimes.
Notice that the input capacitance for the ZTX device with 5V on the drain rises sharply at a Vgs of about 2.1 to 2.2 V. Now look at the curve of Id vs Vgs. It is clear that the device has gone above threshold and turned on and entered the linear region long before the gate voltage at which the input capacitance increased sharply. Indeed, threshold is on the order of only about 1.1V.
More significantly, the device is actually entering a highly non-linear regime in the vicinity of Vgs = 2.1V, where the device is actually running out of gas. Look at the Id vs vgs curve. It actually goes flat at vgs of about 2.2V. Were this a vertical power MOSFET like an IRfp240, this would correspond to an enormously high current, way in excess of 10 Amps, a current that we virtually never go to in normal linear operation on a per-device basis.
Let me know what you think. I could be wrong.
In any case, thanks for doing these interesting measurements.
Bob
estuart said:
Hi Rodlfo,
I see, the added complexity basically stemming from the common source configuration. Remarkably, the sensing differential is configured like mine, another example of convergent ideas !!
As to the other thread pointed by Alex, I did not notice it (it started later than my linked posts) but aim to the same idea and similar implementations.
A further comment, I noticed both compensation capacitors in the control feedback loop, or the inclusion of operational amplifiers. I should strongly advise against this.
Compensation should not be necessary with proper transistor selection and loop gain. Remember the circuit is fully operational in the crossover region and beyond so it is contributing to output stage bandwidth / pole distribution. I prefer to keep it as unobstrusive as practical keeping the highest bandwidth through a minimum of properly selected active devices. By the same token, OpAmps are neither a good idea here except may be wideband ones, but in any case there is no need for very large loop gain since we are not interested in keeping an exact standby current, only some reasonable current at all to prevent power device switching from cutoff to conduction.
Rodolfo
Bob Cordell said:Notice that the input capacitance for the ZTX device with 5V on the drain rises sharply at a Vgs of about 2.1 to 2.2 V. Now look at the curve of Id vs Vgs. It is clear that the device has gone above threshold and turned on and entered the linear region long before the gate voltage at which the input capacitance increased sharply. Indeed, threshold is on the order of only about 1.1V.
Hi Bob,
the Id curve for ZVN device is a logarithmic one and it is other way around - it does not go "flat" at 2.2 V but rather goes from what called a "subthreshold" area, where the Id depends on Vgs logarithmically (so it looks "linear" on a log scale), to a "normal" square-law region which just looks "flat". I've got the same graph on a linear scale and will post it later - you'll see the difference. Actual Ciss "jump" corresponds to Id 0f 1-40 mA area for this device
BTW, this "subthreshold" area also is not simulated properly in most SPICE MOSFET models .
As you may see from the latest data I've posted in my thread, IRL530N does this "capacitance jump" in the area of 2V with 5V on the drain. It corresponds to a drain current between few tens of mA and about 0.5A (I didn't have a heatsink on the device so measured it quickly at the highest point ) .
It looks like a really serious problem in MOSFET linear applications.
Cheers
Alex
We have member MarcelvdG, (http://www.diyaudio.com/forums/member.php?s=&action=getinfo&userid=5881)is he the one who wrote this article?"Audio power with a new loop", Marcel van de Gevel, EW, Feb., 1996, pp.140-143
Compensation should not be necessary with proper transistor selection and loop gain. Remember the circuit is fully operational in the crossover region and beyond so it is contributing to output stage bandwidth / pole distribution. I prefer to keep it as unobstrusive as practical keeping the highest bandwidth through a minimum of properly selected active devices. By the same token, OpAmps are neither a good idea here ................
Rodolfo
Hi Rodolfo,
I also don't understand why Marcel used these compensating caps (and that funny Q8). Anyhow, I fully agree with you on that matter. In Marcel's real implementation, there is no op-amp (that was my idea to simplify the schematic), rather a discrete input stage.
BTW, are you buzzy with real common source O/P stages? As a matter of fact I do, but these sky rocketing Cgd's at full output swing are a nightmare.
- Bob Cordell Interview: BJT vs. MOSFET
