Hi
After 2 hours of research, I couldn't find any answer to my problem.
On a Macbook, I play flac or ape files with VLC thru one USB port, one USB/SPDIF converter, a DAC, a preamp, one amp and loudspeakers. Works OK.
Now I want to get the same result with the Mac separated from the other devices by four meters, trough bluetooth or what ever.
How can I manage that ?
Any answer is welcomed.
OK, but how do I implement that ?
plug dc power in, plug 6.35mm to rca in the output, and connect it to your speaker. turn on computer, and pairing blooth.
There are even less expensive solutions, I just tested this today:
KRC-86B Bluetooth 4.0 Stereo Audio Receiver Module
So you want to extend the USB wirelessly?hey guys, you're on the wrong way.
I want to play flac files THRU a DAC so in digital shape.
The devices that you advocate don't do the job.
How to share USB over Wi-Fi
- Digital Source
- bluetooth
