https://www.dx.com/p/bluetooth-mp3-...ort-fm-remote-black-white-202155#.VAm9d8ko5vk
Bluetooth MP3 Decoding Board Module w/ SD Card Slot / USB 2.0 Port / FM / Remote - Black + White*Display Mode: Single cycle and repeat all switch, it is repeat all as opening*
- Menu Language: English
- Display Size: 1.5"
- Memory Card Type: SD*
- Max Extended Capacity: 8GB
- Audio Formats: MP3 / WMA
- Tuner Bands: FM
- FM Frequency: 85~108MHz
- Other Connections: 1 x USB 2.0 / 1 x SD card slot
- Power Supply: 12V
- Voltage: 7~12V
- The interval between installation hold: 90mm
- Supports external signal switch directly
- Supports Bluetooth 3.0 EDR
- Supports USB / SD card / Bluetooth / FM / Line auto switch
- Built-in MP3 / WMA song decoding chip
- Supports play from USB / SD card / MMC card
- Supports USB / SD card switch PREV / next / fast forward / fast reverse / volume adjustment / play / pause / single cycle / mute / shut off / direct Selection song
- Supports Bluetooth PREV / next / fast forward / fast reverse / volume adjustment / play / pause / single cycle / mute / shut off
- Supports FAT 16 / FAT 32; Supports MP1 layer / MP2 Layer / MP3 Layer
- Supports 32~320Kbps MP3
- Supports power cut memory function: Remember the song and the volume before power cut*
- Working voltage: 12V; Current: 800mA~1A
- Including panel + decoder + remote control + 2-pin plug wire with reverse voltage protection + 3-pin audio plug wire*
- Packing List:
- 1 x MP3 decoding board
- 1 x Remote control (1 x CR2025 battery, included)
- Tuner Bands: FM
- Power Supply: 12V
- Voltage: 7~12V
- Packing List:
any news?There are a lot of parts for this on the marked. good known are CSI, Bluegiga and Laird.
What about differences by sonic quality?
Thanks for advices.
