Blue Velvet preamp
Given what I suspect was the intent of the original designers, I don't believe this would be perceived as a design mistake. I'm quite sure it was deliberate and to a specific end sonically speaking. It is what I call a "tone control" - tongue in cheek.. :D
SY's comment in a previous post about high end audio was pretty much spot on in my experience. (Largely negative..)
Ahhh; it was designed by professionals?
I was wrong in such case. Horrible design. :warped:
I thought it was design of some novice who is trying to learn...
Administrator
Joined 2004
<snip>
Perhaps not quite.. See Black Dahlia | A Day Without Music Is Like a Black and White Sunset
Here's an update to the design: Tip_73
Original article: http://www.enjoythemusic.com/magazine/equipment/1103/midmonth/bluevelvet.htm
His speakers are highly regarded. The pre-amplifier will have to stand on its own merits. To be fair I have not heard one, but I'd imagine it sounds at least OK. The design philosophy overall is not one I would espouse..
The second stage inverting amplifier configuration is clever though.. Something I should have mentioned before.
Administrator
Joined 2004
Hi all, thanks everyone for the comments. I appreciate it. Since I like simple things with less parts, but with good outcome, I will build SRPP preamp by kevinkr.
Ed
I think you will enjoy it.. I am always surprised at how good it sounds when I hook one up as a stand in when I am working on the 26 dht based line stage I normally use.
Would you be interested in the relatively simple regulated B+ supply that I usually use with this design? If so I can draw it up and post it here sometime in the next day or so..
music soothes the savage beast
Joined 2004
Hi kevinkr, please do. However, I will be building it with parts I already have...like hammond trafos, caps, and so on, so I may not be fully following it. Anyway, I want to use DC on heaters, one DC regulator per side, I may even built is as two mono blocks, as I have mono block power amplifiers...will see. I already have 6SN7s, I like to stick to these as I have build headphone amp with these and I love the sound.
It doesn't appear that any of the previous posters actually built a Blue Velvet. I built one back when the article first appeared, and I followed Olsher's circuit and part recommendations pretty closely with one exception---I didn't use his Gas Tube regulator. In any event, the preamp sounded pretty much as prior posters speculated it might. It's dark and heavy, lacking in life. It is a mediocre design. The only mystery to me is why Kara Chafee is associated with it. I would have expected her to suggest better ways of altering the design. I suspect her input on the design was very minor.
Dave
zombie preamp thread
I built kevinkr's SRPP circuit. Its playing right now.
I don't need more gain but I'd like to replace my 12au7 (Bruce Rosenblit ) SRPP with something a little simpler than an Olsen Raven
SRPP 6SN7 (or similar) with gas regulated P/S will do. I need to drive some current so plain resitor loading is out.
Unless someone has a sensiblely priced 10mA linedriving transformer (Lundall are wonderful but..)
Maybe 5687 with 15mA/50V and 15K of resistor (or CSS)?
The Poor mans raven is a simple build really - but not to everyones taste.
A 5687 with a simple CCS plate load will provide excellent performance (much better than the Blue Velvet discussed here). A IXCP10M45 will do a fine job for small money.
Shoog
Thanks Shoog
I'll get "round to" a PMR (or not-so-PMR) eventually but as you've pointed out, there's a fair bit of parts trialling and circuit fettling to get decent performance.
A 5687 with a simple CCS plate load will provide excellent performance ..... A IXCP10M45 will do a fine job for small money.
Thanks for that suggestion - looks like the go. Just got to find some...
