Thanks for your help Promitheus,
I have a little modified bls boards here
i have added a second pair of 1000uf caps in the psu file is avialable here :
http://www.polymorphic.org/~snail/bls/
Considering aleph boards i didnt stated it to cleraly yesterday
i need to choose wich layout will be most universal for this buy - i expect that not everyone wants aleph 5 like me
i have Mark's Layout
and it is really well done but for this bulk buy - BrianGT's layout will be proably better
cos it is more universal - but i only have a driver board and dont have any fet boards in pdf or gerber - only in gif
so if you know where i can find them
that would be great help
so to clarify things:
anyone who wants to participate in this group buy can propose aleph layout and then we will chose one wich suits all of us
PCB production
Hello ALEHP fans,
Maybe you should consider producing the boards in Bulgaria.
Take a look at : http://www.olimex.com
They produce high quality boards at attractive prices.
Piersma
Hello ALEHP fans,
Piersma
Malisz,
If you can mailme this design it would be great
Considering the boards
it slowly becomes clear that for bls /aleph
we will use one sided / without metalized holes / with solder mask / Cu 170um
about aleph: p is it really sonically superior than bls?
did i mention that i want to make 2psu boards for every bls
Hi
Look this
The http://www.elpinpcb.com.pl they have nice proces.
If we make 10-30 one side pcb (aleph +2 psu, bls + 2psu - ca. 10dm2) it should cost ca. 2-2,5$ / 1dm2. Holes and cuts are included.
Its possible to make it golded.
Look this
Could you post them, Promitheus?If you want I have the pdf files from the balanced line stage
and the layouts from Mark Finis also in pdf.
(I´d be interested in the BLS)
TIA
Jens
Once again.
I asked for 200x500 mm boards: one side, drilled, soldermask, tin surface, cutted, description.
I have found two companys. The prices are for one pcb included aleph and bls with 2 psu. Prices do not include 22% VAT.
PRINTOR
10 pcs - 12$ each
20 pcs - 11$ each
50 pcs - 10$ each
ELPIN
10 pcs - 20$ each
30 pcs - 15$ each
PRINTOR
10 pcs - 12$ each
20 pcs - 11$ each
50 pcs - 10$ each
ELPIN
10 pcs - 20$ each
30 pcs - 15$ each
output boards
Guys, have look at this
http://www.diyaudio.com/forums/attachment.php?s=&postid=106470
atough Malisz have mailed me output boards in pdf and hpgl thease ones have much wider traces - but if we decide to use them we shall contact Harvardian first and ask for a permison
He made a group buy for aleph boards and mavbe he still have some of them :
his price was $3.75 per output board
i will try to contact harvardian tomorow
complete where i digged that is:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=9333&perpage=15&pagenumber=3
- bls / aleph boards
