I would recommend to change both XOvers caps at once to be sure both channel will be Xed at the same point
Oh, I did!
The new caps are usually a fair amount smaller, which usually allows you to increase working voltage if desired.
If the caps are 10 years old or older, it never hurts to update them with new quality replacements.
Glad to hear that it worked out for you.
I thought about upping the voltage but frys cap selection was a mess and i got tired hunting after 15 minutes. I'm pretty sure I got the last two that meet my spec.
