Thank you,
I have sourced two locations for a "type" of Linn Black Oil
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=5742935068&rd=1&sspagename=STRK:MEWA:IT&rd=1
and
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=LPGZBEAROIL&Category_Code=PE
a)are either of these the same as Linn Black Oil
b)has anyone tried either
Can I purchase 10ml of the real product (Linn) from anyone or anywhere
again Thank You
and
again Thank You
For turntable bearings I have had the best sucess using BABY OIL .....
It has been around forever, It is light and clear and clean of impurities...It is dirt cheap...It is very clean and pure since it is for babies....
I bet it has had many years of research from J&J to make sure of it's puity....
And you don't need all the hype and marketing BS and $$$ of some trick oil....
I measured the difference with Baby Oil vs. Expensive trick oil...the baby oil had the least amount of bearing drag.....
Chris
Chris
Baby Oil happened by accident...
I use to keep the baby oil in a draw near the turntable...one day I was looking for the strobe platter to check WOW...and then the idea occured to me when I saw the bottle....
I remeasured WOW after using Baby Oil and it made a noticable improvement...
Chris
Chris
