Just ordered a pair of these kevlar 3 inchers for an omni experiment
I've been told they sound v good altho there's a pronounced treble rise. Interested to see what will happen with a bit of tweaking/using as an omni will do the the overall response
SPH-30X/4
30 gbp each from Bluearan ( for the black version)
SPH-30X/4
Tell me about this omni design.
Up firing flooder? Acoustic lens? A Pluto type arrangement?
as soon as I find someone who can turn the reflectors Im going to try that approach.
For the reflector I'll use a simple mock up to test- if it works out on measurements then a cad file/ RP /mould using a carbonology kit
carbonology? Is that carbon fibre composite? I was planning a turned wood reflector, though how well wood would work, and quite what curve to use is beyond my knowledge. Also my TBs phaseplug may complicate matters somewhat.
turned wood will probably be fine. I made a mistake, it wasnt carbonology, it was carbon mods Carbon Fibre Supplies, Carbon Fiber Sheet and High Performance Carbon Fibre Products - Carbon Mods - just ordered their large size mould making kit
SPH 30X were used in Cheap Trick 224 - a small 2.1 set published by Klang und Ton couple of years ago. I did this project last year and the sound is surprisingly good. Did not try the speaker in any other configurations, though.
Pics: LINK. Your kids may like it
I like it !
After ordering these from Blue Aran on the 27th no delivery and no email from the company; so I called up today to find out where my speakers were (quoted 6-7days).
Judging by the reply the order had yet to leave Monacor but will be delivered mid next week "hopefully", apologies "on their behalf for the slight delay"(15 days after order)
not impressed
not impressed
...and then ?
What happened
I received a couple of SPX-20...because I ordered them
in Italy some months ago, and one was slightly defected
So I returned it...and I had to wait another 2 weeks from Monacor too.
They're doing fine, as mid-tw for a two way - as suggested in the brochure
What happened
yes received them finally, maybe a combination of slow delivery from Monacor and Bluearan's lackadaisical customer service. I'm in thailand working on the speaker cabinets and havent rigged them up yet but they are very cute looking
The full model number on these is SPH-30X/4SW
Did you ever get them set up? It's cool that they're available now in black, although the yellow looked great as well!
I'll second that these sound fantastic, dinky little things but these have been my favourite speaker project overall: The Wedge . Sound is very clear and easy to listen to with pretty much anything you throw at them, but whilst being very detailed and rendering vocals faithfully. They also play to a much higher level than you'd imagine, remaining totally clear and producing a surprising sense of scale. I used a notch filter around 10kHz in my design.
Might be tempted to build a second pair with the black drivers and a black with metal accents finish
For anyone still keen on using these, the P Audio SN3-30N appears to be the same (as the yellow Monacor) driver.
The frame looks improved, but all else is equivalent. Mine measure the same as is shown on this Monacor graph - if I apply as much smoothing*.
| Monacor 104410 |Fuldtonehjttaler 3 SPH-30X/8 Hjttaler-enheder Fuldtone-enheder
My feeling is that either unit is overpriced.
*edit: looking again at that graph in the link, the 10kHz peak on mine is only about +6dB, not the 13dB or so of the originals. Amazing.
- Full Range
- black kevlar Monacor SPH 30X/4
