pinkmouse said:Interesting. What happens if you crank it up to about 10w?
The result is better. Right now I unfortunately do not have time to repeat measurements. I will do it for various power levels and show the results later.
Bivoj, at 25W/4 ohm.
THD = 0.02%. The resulting number looks good, but spectral result is horrible. And it is audible.
http://web.telecom.cz/macura/549_25w.gif
pinkmouse said:my current project
Duh, even on a 19" TFT that pcb logo reads as pinkabuse.
The taily thing in front of it looks nice though.
Dat is geweldig DIY
Dear Pavel, you wrote on 03-02-2003 at
http://www.diyaudio.com/forums/showthread.php?s=&threadid=5318&perpage=10&pagenumber=5
'OPA549 (or OPA541 etc.) is not the best solution for hi-end amp. You should not use higher gain than 2x - 4x. The circuit has low GBW (1 MHz) and there is not enough feedback for higher frequencies, this resulting in rapidly rising distortion at higher frequencies.
I would recommend this circuit as a car or basement amplifier, no hi-fi.'
Has your opinion akinda changed now? As for me OPA549 at lower gains sounds
not worse than 3886 or 7294 or something similar.
How "Bivoj" can be translated into English by the way?
Hi Serge,
I have not changed my mind, I do not like neither OPA549, nor any other chipamp. They all suffer from the problem indicated here - crossover distortion residuals of high order.
"Bivoj" cannot be translated, it was a mythological person of Slavonic (czech) history and fairy tales. A strong man who killed a boar by strong hands
Pavel,
wasn't that story called Bivojovi ?
(i've seen a great many filmed Czech fairy tales, German television used to broadcast a lot of them)
The Czech republic must be a land with a romantic twist, and humor.
Even "robot" Capek wrote fairy tales.
How do you explain the chip-amp euforia ?
Upupa Epops said:Maybe " Black gates " will help... and silver heatsink, silver wires etc. ....
Naked "Black gates" ?
You forgot inputcaps larger and more expensive than the rest of the amp...
Mike
Pavel,
many of the chip-fetishists on orange crates in this audio arena seem to be anything but newcomers.
I've put a couple of chip-amps together a year ago.
Can't honestly say they're that much more exciting than the philips tda things from when i still had lots of hair in exposed places.
And chippendale amps do not combine with a great many of the loudspeaker systems i prefer.
I like your creation Pavel,
would love to have a pcb printer on my home computer....ctrl-p and up you go!
To Jacco: new chipamps are capable of moving a central heating radiator when near to a magnet... I use a class D chipamp for my ESL speakers, is that what you were referring to?
And believe me, chipamps will take over eventually....inevitably.....
v-bro said:would love to have a pcb printer on my home computer....ctrl-p and up you go
Find an HP flatbed plotter, my g/f got me one from a dumpster on garbage day, came with a bag of ink pens and all hookup wires. Crazy dame, ever seen an MD going through a dumpster ?
Fill some pens with etch resisted ink, and voila.
Personally, i don't see class D circuits as chip amplifiers, this forum doesn't either i believe.
Denomating class D as an integrated amplifier concept is like saying it is digital.
I don't share your glorious vision of the future either.
Agreed.
I have the same feeling, they remind me 2020 and 2030 chips.
jacco vermeulen said:Find a HP flatbed plotter, my g/f got me one from a dumpster on garbage day, came with a bag of ink pens and all hookup wires. Crazy dame, ever seen an MD going through a dumpster ?
Good one! I thought it would involve vertical drilling, this seems much easier... But can it produce precision SMD multilayer boards? I guess the metalised holes are no option...
Are you guys referring to standard A-B IC amps or gainclones, saying they aren't more exciting than philips TDA...2020 2030 chips?
- Chip Amps
- "Bivoj" - the new chipamp
