In PA applications, Neither Peavey nor the punters will be too concerned about optimum bias conditions for low signal levels. Domestic Hi-fi users are another deal altogether. Many will be using large amplifiers at only 1-5W average levels for the sake of domestic harmony, hearing longevity etc. I think they have reason for concern about anything short of perfection around the crossover region.Like Peavey, I am a fan of as low a bias as possible....
additional stability of the idle current through the output stage provides a compound darlington topology (Sziklai) - go to post #36 abouta massive number of small or medium BjTs with 10Ω until 50Ω emnitter resistor for operating in parallel mode instead of one pair power devices and one pair emitter resistors is the royal way for a maximum of stability for the bias voltage and resulting idle current is the royal way from my view.
check out post 35 and 36 under this thread:
http://www.diyaudio.com/forums/soli...s-paralleled-place-one-output-transistor.html
and this:
http://www.firstwatt.com/pdf/art_beast.pdf
http://www.diyaudio.com/forums/pass-labs/150048-beast-thousand-jfets.html
http://www.diyaudio.com/forums/pass-labs/228203-article-beast-thousand-jfets.html
from this amp I want to have a schematic:
http://www.diyaudio.com/forums/soli...-amplifier-ia-120-ia120-schematic-wanted.html
http://www.diyaudio.com/forums/pass...erview-schematic-collection-all-models-4.html
this approach is also often to note by amplifier for stages and instruments - i. e. public address applications. The distortion is even low enough without idle current through the compond output stage, because the driver provides arround 20mA to output - dependend from the value of the resistor between base and emitter of parallel mode power BjT devices.
Efficiency is at such adjustment close by such kind of amps in Class D mode.
What is effecting the target 26mV?
Both. To be picky, you should include (base resistance / current gain) as well. e.g. if current gain = 100 and you add a 2 Ohm base stopper resistor, that's equivalent to adding an extra 0.02 Ohms of emitter resistance (equivalent in the context of bias calculations).Do I include the emitter internal resistance, or is is just the external emitter resistor?
