FM low power transmitter
My recommendation is to get a low power 12 volt power supply and use one of the cheap "fm modulators" which are actually closed loop transmitters designed to fit between a car radio antenna and the radio itself to inject an outside audio source into the car radio. If you cheat and connect its output to a car radio whip antenna instead, it will probably work for at least a couple of hundred feet. That's not actually legal but it's unlikely to go beyond your property line and disturb any neighbors so it hardly matters. These things cost about $25-50 and you could buy a half amp 12 volt wall wart to power it for another $15 or so.I've really been getting into web broadcasts for a huge variety of music. I have a little hp mini in my workshop that feeds the stereo system.
I live on two acres of property in a lightly populated rural area. I'd like to be able to xmit the station I'm currently listening to on an open freq so that I can listen via any portable FM radio that's handy for yard projects, working on my motorcycle out in the driveway, etc.
I did a little googling but am not really sure what might be the most appropriate, straightforward, and cheapest solution. Have seen many types of USB fm xmitters that I suspect are for very very short distance (same room). There are also the more involved fm xmitter standalone devices that are more powerful and expensive.
I might be wrong, but I suspect that a small fractional wattage xmitter for personal use like this is not bending any rules or requiring any paperwork.
Any suggestions?
Unit soldered to rabbit ears and vertically hung in upstairs closet.
Common rabbit ears are an ultra simple, inherently balanced, di-pole antenna. Cut the twin flat lead, common to all of these antennas, as short as possible, soldered to the board of the xmitter. I hung it vertically in an upstairs closet out of the way of harm, extended the telescoping elements according to a dipole calculator online for 106.3hz and ran 12ft of USB through the floor down to the workshop and plugged into my HP mini 110. I Xmit on a freq as far from any local broadcasts as possible and set the xmit to pretty much stop at my 2 acre fence.
Old post so sorry for digging up - if your still on this board, how did you connect the FM transmitter to the antenna? One side of the di-pole (top) to the antenna wire from the transmitter and then a common ground of the usb transmitter to the other side (bottom) of the antenna? Or is there another ground on the transmitter I should use?
