i have just finished my amplifier with 26 as driver .
26 CCS plate , filament bias ( tentlabs CCS)
5ma 140v
RC coupled
AD1 emission labs autobias. 245V 60 ma
better than my first version with 6N6p driver
5ma 140v
RC coupled
hashimoto 2.5K not so clean inside but i made it in one day...
This is really up my street. I've been experimenting with different DHT small tubes for 3 years in 300b SETs. In terms of input tubes I found I liked in approximately this order:
26 - my preferred option for tone and overall magic
10Y - capable of great clarity and dynamics, but I missed the 26
01A - very good, but not as magical as 26 or clear as 10Y
30sp (VT67) - surprisingly good, less microphonic than 30
46 - usually a driver tube, but very neutral with good tone
1G6G/GT - surprisingly good but very microphonic, so needs special mounting
I currently use a cheap solution - two Hammond 156C chokes of 150H, in series making 300H.
Not that it matters Andy, but wouldn't two identiacal chokes in series be four times the inductance? (N-squared?) Not to nit-pick on you, but I just need to check on my own knowledge - that it isn't all wrong.
I have some 1G6Gs, think I might try them. How about 3A5s? I bought a bunch to use in guitar pedals, but my ignorent me didn't think about how microphonic DHTs must be, so I have them in a box waiting for a reason to be.
Two chokes in series are double the inductance and half the capacitance, so good news with the 156C.
1G6G is a misprint - should be 1G4G. The round plate GT version is also nice. These are quite microphonic. The 3a5 is less microphonic, and it's easy to find two or three rubber O-rings to slip over the bottle to dampen it further.
Andy
Andy
for the tentlabs filament , i have ordered the low noise model for the 26 and it is given for 1 amp max so after two hours of listening i have one side off with the temperature auto shutoff .. the side in fault has a 20cm cable to the tubes so i change his place and now have 10cm after the module and it seems ok ....... at this time!
- Tubes / Valves
- Best input DHT tube?
