Best Full Range for 1.64 Liter Small Cabinet
Hi again everyone! :) Here I am again with my questions. :) Thank you for your patience!
I simmed a number of small full range drivers in a nifty sealed 1.64 liter cylinder enclosure I have, and here's what I came up with:
The orange line is the Fostex FF85WK (Qtc 0.70)
The green line is the Fostex FF105WK (Qtc 0.82)
The red line is the Fountek FR88EX (Qtc 0.63)
The light blue line is the Alpair 7 (Qtc 1.05)
The yellow line is the Alpair 6M (Qtc 0.75)
As you can see, these small drivers all appear to roll off below 150-200 Hz in such a small enclosure. The cabinet is sealed. I could add a port tube if it's very short. Ideally, I'd like to make it down to 100 Hz to cross to the subwoofer at that frequency. Not possible in such a small cabinet?
What about room reinforcement? They will be near a wall... any help there?
Am I missing a good driver for this application? If so, please mention the model number in your reply. :)
Also, would the 'honking'/'boxy'/'cupped hands' problem, if any, be eliminated or mitigated by the sides being round (it's a cylinder as mentioned and the driver is mounted in the end of it)?
It sounds as if you intend to mount the driver at the end of the tube - what is the ID?
Of the drivers listed, I think the 2 most likely to work well in this application would be the FF85WK and the FR88EX.
I know that Dave has played with something along the same lines, I think with a small Alpair and SEAS FR?
Thanks Chris - the ID is 4-7/16" or about 113 mm.
I like what I have read about the FF85WK, but not sure with its very small xmax and size if it would make it to 100 Hz in such a small cab. Maybe in-room they do? What about 150 Hz?
I have the Founteks (they are playing right now actually) and they sound quite nice (different cab though and I don't want to take them apart to experiment, unfortunately). I would not mind a little bit extra vocal intelligibility though and it sounds like the other drivers mentioned might provide that.
frugal-phile™
Joined 2001
The issue with venting it, is that the vent is of significant size.
attachment.php
Here is 1.5 litre box (+ driver + vent). The box could be shrunk by using a 5/8", 3/4" or1" tube instead (recalc the length and subtract the reduced vent volume from the extent of the box. A small enuff vent could avoid the bend if exiting out top or bottom.Changing Port Size
Simulation shows F3 @ 100, F10@70 with a bump (1 dB or so) before it starts dropping.
dave
Thank you, Dave. :) I've always admired your drafting skills. The thing is, the Alp 6 and Alp 7 and the others all seem to sim about the same in this small cylinder box. With a port, the only place it could go is on the back of the cylinder facing the driver, which will surely transmit midrange frequencies out the back. So, probably sealed.
For example, (all in 1.64 liters):
Alp 6M vented F3 = 99 Hz (port tuned to 65 Hz, 3/4" x 4.22")
Alp 6M sealed F3 = 117 Hz (Qtc 0.75)
Alp 7 vented F3 = 102 Hz (port tuned to 60 Hz, 3/4" x 5.05")
Alp 7 sealed F3 = 106 Hz (Qtc 1.05)
So, I guess the real question is, would the in-room results sound thin and not reach 100 Hz or even 150 Hz in practice? Sometimes there is a big difference between theory and practice! What about room boundary reinforcement, does that come into play?
frugal-phile™
Joined 2001
Actually, given that you probably haven't accounted for the driver volume (i'm guessing), you would probably need to stick it out the back (ie external).
That Q too high, and makes getting anything vented not a real option.
and F3 is not really that useful an indication sonically... F6 & F10 are more important.
dave
Try a 4.5 inch BMR
You could try the 4.5 inch BMR 's, they are really good, way better than the smaller units.
Also the Neo magnet version has lots of clear space behind the magnet, the Ferrite version has no room. You can easily hear the difference and its well worth paying the extra ( Neo is abbout twice the price of Ferrite) for the Neo.
I have been getting fab rusults in a 2 litre sealed cabinet, 8 drivers per channel in the attached design, up to 18 per channel in another version with edge to edge driver fitting.
Just as a point of reference, in the same enclosure the 4.5 inch BMR has way better bass and midrange than the Alloy Ted Jordan units, the TJ goes higher ( but is a bit rougher) in the top.
Hope this helps
Cheers
Derek.
Hope this helps
Cheers
Derek.
Which BMRs are these?
Type of BMR
I got mine direct from China a couple of years ago, 300 MOQ, had some left over from a commercial job, they are very similar to the CSS Cotswold Sound Systems Neo 4.5 inch.
If anything the CSS are even better as they did some more R&D into balancing the driver.
Cheers
Derek.
Thanks for all of the input! I do have a nice subwoofer (just one). I'm just wondering if any of these would go low enough in the tiny cylinder cabinets I have to interface with the sub. I don't own all of the drivers mentioned, unfortunately. I'm just going on what others have said about them.
External port might be an option, but it might look a little bit silly.
Sealed Alp 7 with high Q could work, maybe the hump would actually provide a stronger sounding mid and upper bass to interface with the sub. Just a guess!
The other drivers have a slightly flatter response in the sim.
I like the price / supposed mid range magic of the FF85WK but I think with the tiny xmax a FAST system would be required to sound right on that one. (In this thread I'm trying to see what can be done without going in the FAST direction.)
frugal-phile™
Joined 2001
The FF85 is very limited at a 100 Hz. I dolove watching people's jaws drop when i play them by themselves in my big room (with carefully selected material).
When the woofTs are hooked up, i don't have to make any excuses (amazing how well those 4" Peerless midbass do, now working on a design with 4 of them).
dave
Here are a couple FF85wk in your cylinder. Some resistance in the vent would damp down the bump in the vented box. Below 200 Hz xMax is being exceeded with 1W. Not a big deal nearfield, you likely won't be playing them lud enuff to impact that significantly.
dave
Hi Dave, thanks so much for taking the time to sim the Fostex in the small cylinder. Estimating xmax issues in theoretical models is beyond my current expertise, so thanks for that. Sounds like they won't work for this application as listening distance will be 8 feet or so.
Will consider if I go for FAST. :)
I don't suppose you have tried the HiWave HIBM65C20-8 (it's a BMR)? They are only $6.33 at PE. How could they be that good for the price, right? The datasheet shows a midrange dip at resonance though.
No 4.5 inch Neo version in USA
Looks like Parts Express are only selling the low end BMR drivers, they are good for TV, portable radio and the like but not good for Hi Fi or Home Cinema.
Also the 4.5 inch BMR 's still need to used in groups, mini line array of 4 or drivers per channel, even better 12 to 18 drivers per channel.
Cheers
Derek.
