Vituixcad is now freeware!
A very capable set of simulations, including 3D power response! Good instructions!
^Thanks go to kimmosto! Frequent updates and large online library of driver data!
Vituixcad manual was written by jlaakso http://kimmosaunisto.net/Software/VituixCAD/VituixCAD_help_10.pdf
Wine may have some issues e.g. with graphics and tooltips - probably depending on Linux distro.
VituixCAD (which is using .NET engine) is modified also for Wine users to avoid the most obvious problems with tooltips, semi-transparency of graphic lines and vertical texts. It's tested and at least usable on Ubuntu + Wine, but cannot promise 100% compatibility at the moment. Mono could be one way, but that doesn't look tempting at the moment. Main platform will be Windows.
Savonian anti-superhero vituixmän has published VituixCAD 1.0 as freeware.
This is awesome! Nimestä vielä erikoispisteet
Vituixcad freeware: Wow! Is a tutorial of sorts for Vituixcad. Some of it seems self-explanatory, but still..
:do you guys know LscpCAD 5.1 Pro is also freeware?
best kept secret in ls design.
Let us now hope FineCone one day will also be freeware..
Eelco
Where can we download LspCAD 5.1 pro, in IJdata website there is only version 6.1
VituixCAD version 2.0 is out for a year now, looks like the desiger did a lot of work last/updates last year. VituixCAD 2.0.10.7 (2019-01-20) is released today.
See Software
See Software
try SATlive and LEVELcheck
SATlive Audio Measurement Software - for FFT
LevelCheck - for SPL logging
Windos software XP - W10
also runs with wine under linux and mac some users told me - perhaps not really smooth but try it.
We would need a software which can place drivers into a baffle, calculate baffle shape and optimal, from a listening position of like 20 degrees , 2.5 meters etc.
The xo is already hard, we should optimize the baffle shape and driver placement with a software, by hand it is too hard.
What's the fun in that?We would need a software which can place drivers into a baffle, calculate baffle shape and optimal, from a listening position of like 20 degrees , 2.5 meters etc.
If you don't want to design speaker, than just build existing design.
- Design & Build
- Software Tools
- Best FREE loudspeaker design software?
