Best buffer for PIMETA?
The spec sheet for the 8620 says something like MAX SUPPLY VOLTAGE: 24.7V , and the exact same field in the 843 data sheet says MAX SUPPLY VOLTAGE: 18V . I had always read that the 8620 should not be run with more than 24V supply. So you can see why it appears the way it did to me. Anyway, I'm glad to be wrong in this case.
Thanks again for the thorough prompt reply...
