Hi everyone
I bought one of these from eBay
100W Mono Audio Power Amplifier Board TDA7294 HUS | eBay
Thought it should be as simple as wiring it up, but it doesn't seem so. I've checked the voltages on the pins and they appear correct, I'm supplying a signal strong enough to drive a set of headphones, but getting no sound out of this at all?
Not quite sure what the relay is in there for?
Anyone got any ideas or a link to where someone's successfully used one of these boards?
Many thanks
Many thanks
Do you hear the solenoid click closed after you apply power?
No, I hear nothing
bTW. I'm using a 24v ac laptop ps with no center tap, will that matter? I could create a center tap with 2 100 ohm resistors if needed
That's your problem! The advert states it requires a 28-0-28 transformer.
Its also not really intended or ideal for driving headphones.
I'll try an artificial CT with two resistors
Sorry, I wasn't clear, I'm not using it to drive headphones, I was just saying that my audio ip signal was high enough to just drive a set of headphones. I've got it connected to an 8 ohm speaker
Thanks for the reply, I'll let you know how I get on
Obtain a center tapped transformer of proper voltage and current. Be sure to add a large heatsink to the IC.
Also these things are cheap with free shipping for a reason. They are junk.
Cheers. Heatsink on there, why wouldn't it work the way I have it wired?
Yes in appreciate for £10 they aren't gong to set the world on fire, maybe just my house, it was just for a try-out
This amp is designed to be powered by a two times 28 Volt AC transformer. This will produce a positive and a negative voltage of 39 Volt DC. (39 0 -39)
If the PSU you have used does not have the correct voltages and polarity the amp will not work. For one thing, the relay needs the higher voltage and there may be an under-voltage protection.
I agree...I hope you're not planning to drive a valued set of speakers, it could end in big disappointment.
Mike
Quick question, can I use a transformer with dual 28v secondaries? Or do I specifically need one with a centre tap?
Anyone know any UK suppliers?
Yes, bond two of the secondary leads together so that you get 56 volts across the open two leads. It may read higher unloaded.
Thanks for that, do I need two 28v secondaries or 2 14v ones?
To get 28-0-28 AC; you need to pot two 28V secondaries in "series" and use the connection between them as "0".
BTW; the chip might possibly work on lower voltages as well; so if you have a 18-0-18 or 24-0-24 lying around that might work too.
YMMV.
Hi Jcanderton,
I would recommend NOT using a 28-0-28 transformer. At that voltage level you're risking a possible over-voltage situation if the mains voltage is running too high. Worst case could end up with rail voltages as high as +/- 44 volts which would exceed the limits of the chip.
Mike
Mike
- Chip Amps
- Beginner issues with eBay chip amp
