Dear All,
I am a beginner.
I got fascinated with Hi-Fi Audio recently. (Got Lenovo Z2 Plus, but failed to enable Hi-Fi audio)
Browsing numerous sites and forums for help but could not do much.
Got a DIY DAC based on AK4495SEQ on DIYINHK:
768kHz/32Bit AK4495SEQ DAC, I2S/DSD input - DIYINHK
I can understand that I need other things like Power transformers but still stuck on exact components needed
Need your expert help in building complete DAC. Please help on the additional components that I need to build this DAC completely. If you can share the links of those components, will help me like anything.
Thank you.
Regards,
Amit
I am a beginner.
Thank you.
Regards,
Amit
Thank you Timmythediyguy, much appreciated.
Some of my observations:
DAC board power requirements:
one 3.3V (>300mA)
one 5.0V (>100mA)
one +-12V (>100mA)
XMOS 768K power requirements:
XMOS 768kHz DXD DSD512(DSD1024) high-quality USB to I2S/DSD PCB - DIYINHK
3.3V around 800mA
1.3"OLED and rotary encoder volume control PCB
1.3"OLED and rotary encoder volume control PCB - DIYINHK
3.3V around 50mA
D2X High Fidelity Headphone Amplifier
D2X High Fidelity Headphone Amplifier - DIYINHK
+-12V 150mA
Some regulator references:
Classic Reference 78xx power supply linear regulator +-12V
http://www.diyinhk.com/shop/audio-k...r-regulator-33v-5v-12v.html#/78xx_option-_12v
+12V regulator used: LM7812ACT
-12V regulator used: LM7912
Not sure of the input voltage
1.0uV Ultralow noise DAC power supply regulator 3.3V 5.0V 800mA
http://www.diyinhk.com/shop/audio-k...dac-power-supply-regulator-33v-50v-800ma.html
3.3V regulator: ADM7150ARDZ
As per PCB screenshot:
Input voltage for 3.3V output: AC ~7V
Input voltage for 5V output: AC ~9V
4.17uV Ultralow noise DAC power supply regulator +-12/15V 1A
http://www.diyinhk.com/shop/audio-k...oise-dac-power-supply-regulator-1215v-1a.html
Regulator used: TPS7A4700
Input voltage: AC ~15V-18V
4.17uV Ultralow noise DAC power supply regulator 3.3V/5V 1Ax2
http://www.diyinhk.com/shop/audio-k...e-dac-power-supply-regulator-33v55v-1ax4.html
0.8uV Ultralow noise DAC power supply regulator +-9/12/15V 1.5A*x2
http://www.diyinhk.com/shop/audio-k...-dac-power-supply-regulator-91215v-15ax2.html
Regulator used: LT3042
Looks like Input voltage: AC ~15V-18V
0.8uV Ultralow noise DAC power supply regulator 3.3/5/7V 1.5A*x2
http://www.diyinhk.com/shop/audio-k...e-dac-power-supply-regulator-3357v-15ax2.html
0.56uV Ultralow noise DAC power supply regulator 3.3/5/7V 2A*x2
http://www.diyinhk.com/shop/audio-k...e-dac-power-supply-regulator-3357v-14ax2.html
Regulator used: LT3045
A couple of requests:
1. Please help me with the appropriate voltage regulator
2. Is Headphone Amp needed. If yes, have I selected a good one?
Please help.
Regards,
Amit
one 3.3V (>300mA)
one 5.0V (>100mA)
one +-12V (>100mA)
3.3V around 800mA
3.3V around 50mA
+-12V 150mA
Please help.
Regards,
Amit
