With the outputs out of the circuit, the shutdown pin should be pulled high by the 20k resistor (R19?). If the resistor is within tolerance, it's possible that the IC has failed. The 5.9v on the 5.1v regulator output is well out of tolerance and often indicates that the IC has failed.
After replacing the SG3526 with a UC3526 the controller started fine, didn't touch R34. I had output coming from the IC. The down side, the bulk caps are all leaky. That I believe to be the original failure for this amp. The electolytic from the caps was all over the board, I didn't realize it before. I do now after I powered it up and see arcing. Time to order some caps!
cory
cory
I wouldn't replace them. If there isn't any adhesive between the primary filter capacitors, twist them to see if any have broken legs. If not, apply a tiny bit of adhesive to the tops of the capacitors to hold them together and to prevent the leads from breaking in the future.
It could be RFI from the class D section of the amp.
If the antenna isn't permanently mounted, try moving it away from the amp. If that doesn't help, check the shield on the antenna to confirm that it's intact.
Also confirm that you read 0 ohms from the ground terminal of the amp to the heatsink of the amp.
- General Interest
- Car Audio
- BD1000 wont start up
