lineup said:
This low noise riaa
is easy to build - opamp style with common transistors
and will have very great performance - if my sims are somewhat correct.
I think a good PCB prototype silksheet
would be of interest and use for 'Analogue people'
Now
when the hype of the day is about Low Noise
this project is interesting.
It shows what we can do by using low cost transistors
---> in parallell
to achieve reduced input noise
2T - 3dB
4T - 6dB lower noise, as used in my symmetrical design here ~ half the noise
8T - 9dB
16T - 12 dB, same as 1/4 of noise of 1T
Lineup good & low cost audio regards
peranders said:It looks like the Elektor SUPA, decades ago.
It is indeed - more-or-less.
Just a week ago I fiddled with this circuit (Elektor) but I got no sound from my modules...
D
peranders said:I'll guess you have to trouble shoot then. Have you checked the currents in the amp?
Chucked it in the parts bin... I now use an EAR 834P from a friend!
I am just not that good at understanding electronic circuits...
D
3 Circuits provided by Lineup
Som links lownoise circuits to explore:
LowNoise multi parallelled differential BC550 bipolar input RIAA (from old Elektor originally)
http://www.diyaudio.com/forums/showthread.php?threadid=91497
LSK389 JFET input pair to LowNoise bipolar Op-amp
http://www.diyaudio.com/forums/showthread.php?postid=1519372#post1519372
Cicuit: http://www.diyaudio.com/forums/attachment.php?s=&postid=1519372&stamp=1211672608
syn08 circuit:
http://www.synaesthesia.ca/files/headamp.png
Let's hear what people think
I just dont like to make gigantic and complicated circuits for the task here
syn08 circuit:
please help me!!!!
hi!
My name is Paul Mesaglio. I'm from Argentina and some time ago I found the "super low noise RIAA phono preamp" magazine Elektror. I'm a big fan of DIY (indeed I create guitar effects called RETROHEADFX) and was about to make me one when I found this forum your modifications. I immediately began to do them but I have some doubts:
Finally the two 15K resistors (R17-R21) are removed or fall?
Is the final circuit of post # 16?
I hope you can answer me because I am very close to finishing the design (Corel do first and then step ALTIUM ... if you're interested I can send files)
thank you very much
ps: sorry for my english
hi!
thank you very much
another thread to the same topic is here:
http://www.diyaudio.com/forums/elektor/121825-sln-pre-amp-elektor-aug-1982-a.html
topology is based on follow:
http://www.diyaudio.com/forums/soli...age-large-voltage-swings-lenders-circuit.html
finished PCB boards you will find here:
Hormann Audio - Hormann-Audio-Produkte
For MM and high output MC a very good solution. For best results a shunt voltage regulation in dual monaural version is necessary.
This was an old thread and all my links are changed. As I mention I have designed a massive overkill RIAA amp
my version of SUPER LOW NOISE RIAA PREAMP
HI
This is my version of the preamplifier. I'm still working hard on it. I added a relay for switching the input to ground or sent to the circuit. I did it with the intention that when changing a vinyl avoid having to lower the volume on your power amp or preamp ... just flipped the mute switch and I can manipulate the vinyl without any noise. Also I added a subsonic filter that can be bypassed by relay. The power supply is also a version of the "salas shunt regulator" .....
again...sorry for my very bad english!!!!
HI
- Analogue Source
- BC550 BC560 Very low noise RIAA
