bass speaker help
Ex-Moderator R.I.P.
Joined 2005
basic idea of the design
Ex-Moderator R.I.P.
Joined 2005
...especially interested in what happens with a 5-string bass... distortion?
-RNM
ahh.. 5 string ? :scratch2: regarding distortion ? you mean if it will exceed Xmax easily ? well, I dont think so
with the small closed backchamber and apperiodic venting, I expect it will stay well controlled, but with a sound I would call 'rich and tuneful'
but not fully tested yet
been busy with my other previous speaker project
just got hold of some more xo parts, and made a very succesful crossover change, and its really good now
but still more work to do on that one too
btw, is that you in the picture ? wow, you look like a real gentleman :)
Ex-Moderator R.I.P.
Joined 2005
yet another xo revision, just in case someone would be tempted to copy this magnificent speaker
since the woofer now got the long missing inductor, I will look at reversing phase on the mid instead of tweeter
and the mid inductor may be a bit too big now
Ex-Moderator R.I.P.
Joined 2005
this one is approved, and finished
works great now
spent a few hard days trying to figure out what went wrong when I implemented a trafo inductor on the woofer
reversing phase on the wrong driver completely screwed the whole speaker
and it screwed up my playing too
makes one wonder how many poorly performing bass systems there are out there :scratch2:
but mine works now, and makes me glad playing again :)
Ex-Moderator R.I.P.
Joined 2005
Just curious...
me too ;)
but was expecting to go active ... later :eek:
just wanted to know if it would be simpler when only for bass guitar
and I almost tend to say, it appears even more 'picky' than for music/hifi
there is no doubt that it affects your playing quite significantly
imagination alone wont do it :D
I choose not to use artificial effects
but it might have been much easier
Ex-Moderator R.I.P.
Joined 2005
.... why do you still use passive crossovers in a Biamped system?
a simple PLLXO line level xo should work nicely for this speaker
unfortunately my present solid state power amp have much too low input impedance
or else I would have tried it instead
but when I build the hi-Z pre out buffer I guess it will be a natural mate
and I also had this weird idea to mate the xo with baxandall controls
