Hi guys, not entirely sure that this is the correct section (I usually hang around the speakers section), but here goes...
I've seen these bass harmonic generators, where a, say, 50Hz note is made into 100, 150, 200Hz, etc, giving the impression of a much deeper bass response than the system actually has.
My old mobile phone had one (they called it MegaBass ), and it sounded like it might actually be putting a little LF out.
I was wondering if there's a chip or circuit board available to consumers that does the same thing, preferably available to the UK (I don't mind importing stuff, but it can get expensive).
The use will be a reasonably small portable boombox (if I get around to making one), where the tradeoff is bass extension or battery life. I'd rather head towards battery life by using a couple of high efficiency midbasses, but I understand that I won't get much below 100Hz.
Thanks in advance,
Chris
Thanks in advance,
Chris
You mean a phase vocoder or TDHS? Are you sure it's not just peaking EQ or a low shelf for a bass boost?
MaxxBass
If you could maybe adapt a PC or MAC laptop as a portable source connected to your boombox, then here is a software plugin that appears to be what you are looking for.
MaxxBass - Bass Enhancer Plugin | Waves
It also appears that the algorithm is available for commercial license on a DSP chip. You might persuade them to send you a single sample or, better yet, a reference design board though. Worth an attempt.
TDL Technology used to offer their model 907 external processor box based upon the MaxxBass technology - featured in the November 2004 issue of AudioXpress.
