Baffle Veneer
What flavor copper should I use?
  • Enchantment
    Votes: 4 44.4%
  • Azul
    Votes: 5 55.6%
  • Total voters
    9
I'm planning on making some Aikos (Spawn family) but I'm super tossed on what veneer I want to use for the super baffle.
The sides will be piano black, the back and front on either side of the super baffle will be zebra wood
I want to have a really nice looking baffle so copper veneer comes to mind, but I can't decide what color I want.
Either the Azul kind or the Enchantment kind
Azul us the blue one and the other one with streaks is enchantment
What do you guys think
http://www.veneersupplies.com/products/Enchantment-Copper-Veneer-24-x-18.html
http://www.veneersupplies.com/products/Azul-Copper-Veneer-24-x-18.html
  • Aiko-1v1-plan-231208.pdf
The enchantment for sure!!!! Having said that bamboo has a similar look and is most likely cheaper.
Neopolitan bamboo veneer or laminated flooring/ plywood similar to the Enchantment, maybe - the Azul, not so much.
kftess5 - what shape/edge profile details did you have in mind for the supra-baffle?
FWIW, I've done a few of these myself, and would suggest an elliptical shape with a "finger-nail" profile routed edge - either in solid hardwood or plywood, and paint.
Keep in mind that the copper is a thin metal sheet, and unless you're quite experienced working with this type of material cutting, pattern matching and edge banding could be tricky, to say the least .
that said, the Azul is stunning
