great foam board build ! the original Karlson K15 with good coaxial excels in many departments including vocals, harpsichord (which sounds gawdawful on a Klipschorn), percussion, sax, whatever. As a punchy horn-killer toy, I'd like a new "K10" which can play 120dB peaks - gotta make a port panel which got lost for a previous 10" coupler build by John Lapaire.
Distributed horizontal slot vents seem a good way to go. The so called "Dutch K12" has huge vents which look like would tune too high but I think the front aperture sets fb in a good range.
the quest for a great baby K which can mate to a sub should go on
Ive got a few small parallel tuned Ks in the works with my main goal to mate well to a sub. I'm getting decent bass out of my parallel Klam. about 3db down at 80 Hz but it either needs a tweeter or a wide notch filter centered around 400 Hz to sound balanced.
a K-tube over a dome, grafted to a piezo element, could serve as your tweeter and you could extend it far enough to reach into the main klam aperture
you can see a long extended pipe with 5.5" K-tube on its end jammed into a coax HF horn mouth "here" https://www.youtube.com/watch?v=mupb8X6iZ6I
