Ooooo- what is THAT cool toy you have there?!? I think I might want one
It's an E-Bay gadget, a very handy toy.
http://www.ebay.co.uk/itm/128-64-LC...744801?hash=item1a0e2969e1:g:rGUAAOSw-zxWndes
This is getting bizzare.
All four NFETs test correct but have been replaced as a matter of course. 4x 9v1 back to back diodes have been installed across the pot wiper and 0V.
There is still no output from either channel.
D2 - the LED - illuminates indicating power to the board.
This might be too basic, but sometimes starting over with the basics is best by using a scope (or get a cheap USB one if you don't have one), put a signal on the input, and put the probe at each stage one at a time to see where you lose the signal exactly. If needed you can check dc voltages with the probe at each lobe also, to see if you are losing voltage where there should be some. Then tell us what you find.
If the JFETs are OK and the PSU is working we have to think of basic problems
I can not imagine coupling capacitors to be both defective. Otherwise i can think of a defective source selector or potentiometer. Would be strange to see two channels defective at the same time.
Still some designers of tube stuff omit muting relays with delayed turn-on and instant turn-off. Also on this forum, one has a hard time convincing such designers of the benefits as they mostly concentrate on their own situation which does not ask for such protection. I wish we could make this item a standard thing on any analog source/buffer/preamp.
Jfets are a little more resistant than Mosfets, but you can still take them
out. All the cases I have seen have to do with Tube sources, usually
the turn on/off transient of somebody's tube preamp.
LED coming on does not guarantee power to the circuit. Most likely reasons for no sound are
1. Power to board from PSU broken (10 seconds to check with DVM)
2. Output ground broken somewhere
I can't think of anything else that would cause a loss of both channels. If those check out then next step is CDP into B1.
When I got the Fluke out I realised that the amp had been connected to one of the inputs and not the output.
Yes, I've done that.
You could change all your RCA/Phono to XLR.Oh I feel such a fool.
The problem with a lot of DIY equipment is that the Inputs and the Outputs are often not marked. I was relying on memory - DOHH !!!!!
The outputs and inputs are deliberately male and female so one cannot mix them up.
Pass DIY Addict
Joined 2000
- B1 has died
