B1 Buffer Preamp
Has anyone built the B1 point to point. i am tempted to try it point to point but not sure how to connect the jfet by looking at the schematics - i meant which leg go to where (in layman term.)
The schematic uses standard symbols. Using the jfet's data sheet, and searching the internet will provide you with the info you need. I put little stickers on mine to make sure I wouldn't mix them up.
After some reading from the suggestion, I think this is how i suppose to connect the JFet chip.
the middle leg or GATE goes to the 1uf cap.
the DRAIN leg goes to 10k resistor, 18V supply, etc...
the SOURCE leg goes to the 10uf cap
Thanks again everyone for your help.
according to the datasheets the pinout of the Tosh and Linear are identical. Linear describe their lsk as a replacement for the Tosh 2sk
It's the other jFETs that come in various pin outs.
I thought they were only made (lincensed by in any way) by Toshiba. We know that they are reaching their End Of Life but, what about the other manufacturers, are they still producing?
Are they really equivalent replacements or just have some thins in common and it's just a commercial approach?
Regards,
Regi
Regards,
Regi
I thought they were no longer being manufactured, but mouser.com lists the Toshiba 2sk170 as a new item.
hhmmm..here goes another pre-Xmax-B1-components-related Q?;)
Can i change the standard Digikey-BOM panasonic C1 and C2 elco
with this one form pana?
it's 10.000μF, which shouldnt be a problem (>1000μF should be okay in B1) but will it fit? Slightly confused about mounting, snap-in, throughhole etcetera.
Pin-diameter is the same @ 0.8mm (sorry, metric-dude here) and distance @ 10mm. Size wouldnt be a problem 25mm x 35mm (wxh) as Digikey-elco is 22x50 mm's.
i gladly welcome all advices and alternatives
Merry Xmas* from the Netherlands:santa3:
*i know....almost...almost...just practising already ;)
