Audiolab 8000a Speaker Protection
Yes a relative novice can adjust the trip limits in an Audiolab 8000A.
The procedure is outlined in the service manual but it is fiddly, I can't
remember the exact details, I think a set of resistor values is needed.
The trip limits should only be adjusted because the load is low impedance.
:)/sreten.
:)/sreten.
Hi Sreten...you wouldn't happen to have a copy of that service manual, would you? ;)
Administrator
Joined 2004
Hi Sreten,
I'd be interested also if it's not too much trouble. I've repaired a few with a schematic only.
I'm still uneasy about messing with the protection circuit. You never want to disable it completely. That is asking for trouble.
-Chris
I't s because it doesn't go as loud as it should before it cuts the power.
When I spoke to Audiolab several years ago and described the other equipment and the listening environment, they said straight away that it must be set too low, but I couldn't afford to have them change it.
If anyone has a guide to doing this I'd appreciate a copy.
Thanks.
please tell me the serial number of the 8000A.
For the correct models the procedure is straightforward,
I was confusing it with resetting the bias.
The procedure prevents the mute relay operating on
high level bass transients into low impedance loads.
:)/sreten.
I have schematics for serial numbers 87........ and 89.............
:)/sreten.
mikeks said:
hi sreten...
Would appreciate a .pdf copy of that manual..
cheers!
I have a photocopied paper version,
quality of some of the A3 diagrams is poor.
At work we are considering implementing our own PBX, one of its
facilities eventually will be FAX to PDF conversion, so we will at some
point in the future we will be able to use a scanner to generate PDF.
Which is fine for the A4 pages, still stuck with the poor quality A3s.
:)/sreten.
:)/sreten.
all you need is pdf995, freely available here:
www.pdf995.com
:)/sreten.
sreten, can you post a complete schematic of Audiolab's SOA protection circuit?
You pretty much have all the info.
(Unless there is some temperature sensing I've missed)
There is no SOA apart from the output current tripping the relay.
(As far as I can tell)
R501/2 and R503/4 are connected to the output pair current
sensing resistors R493/4 2.2R double resistor packages.
:)/sreten.
