audio pipe 1500
the first one is from the Optocoupler one the high side.the second one is from the Optocoupler from the low side. time setting. volts div-.5 time div- 2us
Is the side of the output filter inductor that's connected to the middle leg of the high-side FETs connected to the negative speaker terminal with a jumper? If not, make that connection. Does the signal clear up?
The output transistors appear to be out of the circuit. Do NOT make this connection if the outputs are in the circuit.
Many times, when the cores get too hot, they will no longer work as they should. If you're going to wind a new inductor, I'd suggest using new cores. In the Massive (which is very similar to this amp, from what I've seen), two stacked CM330125 cores with 23 turns of 12g wire make a suitable replacement. They run cooler than the originals and are less likely to short because there are no overlapping windings.
