Hi im looking to replace some Philips electrolyics in my amplifier. They are 47uf/63v. Heres a picture of the amp. there are two differant types of small lytic caps in the amp both are made by Philips. One is a light blue radial type which im going to replace with Cerafines, but the metalic blue axial lead parts are a bit harder to fnd a suitable replacement for. I guess I could just use a radial and leave the leads long, but im not sure this is such a good idea? Anyone know where i could get these caps or something similar or better??
thanks
thanks
Xicon's high temp electrolytic caps are favored by most everyone in the DIY audio world. They're a very vivid green.
Check them out here:
http://www.mouser.com/search/Refine...e matchall&Ntk=Mouser_Wildcards&Ntt=*140htrl*
None exactly rated for 63 volts but going a little higher can't hurt. I've used a LOT of different caps in my audio circuits, the high temp vivid green Xicon's by far sound the best out of the aluminum electrolytic. There is a noticeable difference when I've used these in contrast to so many others. They just seem more detailed and less harsh sounding.
