Hi ian, maybe is a good idea put external i2s input with ufl and trhue hole and don't solder gpio by default. For different application, similar od mcfifo.
Regards and thanks for your job
good point, I am sure like you and me there are more people who use the FiFiPi as general device FiFo-interface
That's a really good idea. I'll put it on my R&D list and make it available soon.
Regards,
Ian
between fifoPi and McFifo... what are the differences ? (aside from the from factor...)
McFifo/McDualXO support multi channels, that's the main difference.
And also McFifo/McDualXO has an independent clock board, so the signal quality could supposed to be better.
However, I'm now working on ReclockPi project. which is basically a secondary re-clock stage to upgrade FifoPi signal quality. I believe FifoPi/ReclockPi combination could have even better signal quality than the MC solution.
Regards,
Ian
As I have read, with Q3 you need to have only 3.3V, as there is no LDO anymore. So take care.Is it possible to use a 5V DC supply for the clean side of the FifiPiQ3, or is 3.3V DC the maximum?
Hi Ian,
I want to ask a question about FIFOPi. The AK4499EQ or ES9028q2m support DSD data stream with fs = 48 kHz, therefore it need a 24.576 MHz clock for this playback. However when I read the datasheet of your FIFOPi, it only mentions DSD with clock frequency group 1 (5.6448 MHz, 22.5792 MHz). So I would like to know if your FIFOPi can proceed the DSD data with fs = 48 kHz
Do you guys, think a 3.2 LiFePo celldirect on Q3 could be ok vs a very low noise 3.3V there ? (or same same result for listening purpose, i.e. for the FifiPo hat above fed by such cells as well ?)
Passive power supplies, such as LifePO4 batteries or ultra capacitors are always better than any active power supply. Thank of the difference between a lake and a water tower with a pump .
Regards,
Ian
Hi Ian,
@trung224,
All DSD formats are the 44.1KHz group. DSD64,128,256,512 .... all of them are.
With FifoPi, you can play DSD at any frequency of 22.xxx, 45.xxxx, 90.xxxx MHz. However, to run at true sync mode, based on ESS data sheet, you will need the a 22.xxx MHz mclk. But the ES9028Q2M DAC was tested can go up to 45.xxx MHz at true sync mode.
I have never see a DSD with 48KHz family frequency. Just hope this helps.
Regards,
Ian
Thanks Ian for your answer,
DSD with fs = 48 kHz family is an Upsampling signal with Signalyst HQPlayer from 24/96 source. It is unorthodox way of DSD though. So it seems FiFoPi can only recognize DSD signal when it is fed with conventional DSD signal.
When will the group buy end? I am preparing to send the order form in the next 2 days
Yes, it is possible.
Thanks for the answers guys.
I read the part about the LDOs in the manual too. It says on page 2:
Uses pure 3.3V for a clean side DC power supply. All LDOs have been removed to allow direct operation with
a better 3.3V power solution via LifePO4 or ultra capacitor.
But further down in the manual on page 9 it says the following, implying that you can use higher voltages if R58 and R59 are not shorted:
With a 3.3V DC input on J5, the on-board LDOs are automatically bypassed internally because of the
dropout voltage is lower than the minimal dropout voltage (about 0.3V).
It is theoretically better to physically bypass on-board LDOs when using one of these supplies. You can solder a 0R
0805 jumper resistor or just a short piece of wire at positions R58, R59 which are located at bottom side of the FiFoPi.
CRITICALLY IMPORTANT NOTE: After you short R58 and R59, the ABSOLUTE MAXIMUM VOLTAGE you can
connect to J5 is 3.6V!!!! Any higher voltage means you will likely damage your FifoPi and clocks.
I can run the McFIFO with a 3.3 lifepo on the dc-input connector ?
maybe you can indicate what regulators are to be bypassed on the board and what are to be left alone.
On the mcdualXo i have already bypassed the local regulators to be able to feed direct 3.3v from batteries.
but on the mcfifo the silkscreen report 5-6 vdc on the input dc connector...
wondering if the concept of the fifopi power scheme apply also here.
thanks
thanks
UC Conditioner 3v3
Hi Ian,
Quick question for clarification as I am looking into running the clock side of FiFoPi directly from a 3,3V UC Conditioner
From the manual it was not so clear to me. Is the conditioner supplying the 3,3 Volt with the "charging PSU" still "connected" or is the 3,3V output just coming from the ultra caps only? And only when the ultra caps are not charged enough they get filled up automatically?
If this is the case:
Is there any experience from you or users, how long the FiFoPi clock side will run between charging cycles? (with the two 325F UCs)
Hi Ian,
@dddac
The DC input to the UcConditioner has to be connected during power on.
With 2 3xxF UCs, it will last around 5 to 10 minutes before the voltage dropped from 3.3V to 3V for a 50mA output current. Unless using 3000F UC, you can not run them independently.
Regards,
Ian
Regards,
Ian
Hello,
I read this here on this site.
BUT I can report that if you are just using 325F/350F UC pairs powering your USBBridge Signature, IF YOU CAN FIND THEM, you are in for a very nice surprise when you replace them with a 3000F Maxwell UC pair... using them took my setups to a new level. Sadly, Maxwell has discontinued units that large and they are getting extremely difficult to find. Does anyone have a good reputable source? I have some coming from a Chinese vendor on EBay, hoping they turn out to be good units and are as good as the ones I already have!
I will wait for Doede to report.
From what i read so far MY mind tells me if you wanna use these few hundreds or thousands F ultracaps you will need a fool proof circuit. Usually my DDDAC is on 24/7 but i assume it is not only me looking for a reliable solution.
These caps are made to '' contain a lot of juice '' and will show off no matter what causes the demand for energy.
Greetings, Eduard
Greetings, Eduard
@Eduard
Yes, 3000F ultra capacitors really make difference. Fortunately I have a pair of Maxwell 3000F capacitor, I can not live without them.
Did you try
https://www.mouser.ca/ProductDetail/Coiltronics-Eaton/XL60-2R9348W-R?qs=bZr6mbWTK5nwwtY5EyYHRg==
and
https://www.mouser.ca/ProductDetail/AVX/SCCZ1EB308SCB?qs=qSfuJ%2Bfl/d5jBP4N6%2BRGlA==
Regards,
Ian
Did you try
and
Regards,
Ian
Hello Ian,
Once i know how i am going to upgrade my DDAC with parts that would benefit from ultracaps AND being sure about how to use these caps safely i will surely try big F number caps with the right voltage. The links take me to 2.7 and 2.9 volts DC rating while so far i just read about 3,3 volt.
Greetings, Eduard
Greetings, Eduard
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
