I just downloaded ARTA to check and was going through the calibration but I'm having a problem. This is on a laptop using the MAudio Firewire 410. At step 1.5.2 for calibrating the inputs, I have the left output looped back to the left input but when I run the generator the bar graph at the bottom doesn't show anything, so I don't know if the input is clipping. The soundcard shows both and input and output signal, confirmed the output with a voltmeter, and doing the same loopback in SE works as expected. Anyone know why the graph isn't showing anything?
When I used ARTA for the first time I had to double check settings and go through my setup a few times before I had everything setup right - both the soundcard settings (turning on "Mic Boost" for instance) and the physical setup. There was a little bit of a learning curve, but not too rough, not nearly as tough as Sound Easy, for instance.
Now, I love it, and no more headaches. It's fast and easy to use, once it's setup Once I figured ARTA out, I gave up trying to get good measurements in LspCAD or Speaker Workshop, because ARTA seemed so much more easy and reliable. The features like the automatic measurement splicing for low + high freqs. and the distortion testing are wonderful to have available in a free version.
Is your laptop's built in sound card disabled in the BIOS?
What happens if you try to do a measurement w/o calibration?
I tried to use an external M-Audio USB soundcard (Transit?) and I got inconsistent results with each program I tried. I bought the cheapest SB Audigy 4 soundcard I could find, and it's working great with all the programs I've tried so far. I had problems with a few different sound cards, I tried a bunch of different drivers too - so many headaches, but now with the cheap new card, it just works - I was about to pull my hair out before that
augerpro said:And this WDM driver would have been included with the soundcard drivers probably?
Should have been, yeah. I don't think ARTA would have been able to make the card put out any voltage without it. Do you have the extensible box checked? I've heard others say that made a difference but I dunno.
