Anyone built an OTL to drive an array, of full range drivers, wired in series? To extract more power, using fewer tubes, with out exceeding the Imax (wich is a parameter that I think most OTL manufactures are ignoring).
OTL
The first commercial OTL's came with special high impedance speakers...
Guess it must be possible to make up an array to simulate a 'high-impedance' speaker, but you may lose imaging/spectral position by using lots of speakers, so you may end up with a worse sound than just using a 'conventional' OTL, and a good conventional and sensitive speaker set up....
