That's how my "High-End" (according to the local store) RCA connectors look like.
I manipulated them with my fingers, and didn't touch them for 2 weeks
Now I can see my fingerprints on them, looks like oxidation. And it don't get away with acetone or alchool
Could this be "false' gold??
Bricolo said:That's how my "High-End" (according to the local store) RCA connectors look like.
Could be. Real gold shouldn't do that. I suppose it's possible that there's no gold on it at all, just polished brass which looks strikingly similar to gold but when handled, can tarnish just as you show in the photograph.
Try dissolving a couple tablespoons of salt in about half a cup of vinegar and see if that removes the fingerprint.
se
Bricolo said:thanks for the tip
should I put the entire connector in this solution, or simply put a little of it on a coton?
Either way. Whichever one you do, just be sure to rinse it off well with some water afterward. Otherwise things will start turning green.
se
SY said:It could also be that what you've got is very thin gold flashing, rather than a nice, hard electroplate.
Yeah, a gold flash directly on the brass with no nickel barrier plating could give similar results I suppose. If that's the case, they're beyond cheap as even the cheap gold flashed stuff typically has a nickel barrier plating. And the "direct" gold plated stuff usually uses a gold/cobalt "hard gold" alloy.
se
There is a commercial product named GoldShine that does miracle to these connectors. It is designed to clean fingerprints from rings and earrings.
On a side note, I often used a product called Silvario to thoroughly clean and add a thin coat of conductive silver to the connectors. The only problem with this product is that you need to reapply a coat every time you mess with the connection.
Both products should be available in your local jewelery store.
Hope this help.
Sébastien
Hope this help.
Sébastien
Bricolo said:Thanks Steeve!
I tryed the vinegar+salt. It's better now.
The fingerprints aren't totally gone, but it's far better
Great! It works well on copper too. I usually use it for cleaning the bottoms of my saucepans.
se
li_gangyi said:you have copper saucepans over there?? Kinda cool~!! We only have stainless steel here...haven tried vinegar and salt...might do it one dae when I help my Momma clean her pots..
Yeah, they're old copper-bottom RevereWare saucepans. The new ones have the copper sandwiched between stainless steel so there's no exposed copper. But I still like my old copper-bottom pans.
se
The best stuff for cleaning and treating connectors I ever used is Caig Laboratories R5 Deoxit and G5S ProGold.
If your connectors are at least a few months old treating them with either one of those is like getting a new piece of gear. The change is not subtle, especially on non-gold plated connectors.
Caig has a whole line of cleaners and treaters. Not that expensive- about $10.00 / 200ml. can. Worth every penny.
se
It works for copper? So my connectors must be brass
Sch3mat1c said:Vinegar with "as much salt as it'll dissolve" also works great on rusted steel, just soak a couple of days!
Yeah? Hadn't tried that. I've always used naval jelly for rust.
se
Bricolo said:I think that for saucepans it causes no problem, but... can the vinegar+salt damage the plastic in my rca?
Can't think of any reason why it would. The vinegar's only mildly acidic. As long as you rinse them off well afterward, I don't foresee any problems.
se
If you really want to find out if something is gold there is a sure fire test but it destroys the gold in the process but is conclusive. The only thing that dissolves gold is "Aqua Regia" - a mixture of Hydrochloric acid and concentrated nitric acid in a 3 : 1 ratio
Dip or paint some AR onto your gold and if it dissappears it is real. This test was use in field by the gold buyers during the gold rushes in history to prove the real stuff. If you what to know if the article is genuine and are prepared to sacrifice one connector it is the way to do it. Where rubber gloves and goggles
David L
David L
- Design & Build
- Parts
- Aren't gold plated connectors supposed to be inoxidable?
