Are There True MOSFet Compliments???
the last, truest complements of vertical mosfets came from toshiba.
i think they're all NLA now.
many have happily used the pairs you mentioned for years.
they're plentiful, cheap and tough - a good combination for diy
fairchild has (had?) some similar parts also.
good luck ,
mlloyd1
To the point, I want to build high power(>100W) F5T. I have alot of IRFP250/9240. I realize they are not true compliments but neither is the 240/9240. Any body see issues with this? Do I have to change anything in the circuit to do this? Thanks for any help.
p and n channel's are never compliments as they are two different structures of transistor. The nearest you will get to them being the same is to use a quasi complimentary output.
Having said that I have been designing amps for many years with 240/9240's and never had a problem.
