amc184 said:Did you adjust the focus offset and check the laser current when you installed the new mech? If not, you will need to.
Hi, yes I readjusted the values, they were different to the other mech.
I set the offset from the value I get whilst it is trying to focus.
I tried the 22k pot in different positions to see what difference it made and if I turn it fully clockwise I at least get the 12" displayed instead of the 8", but still with the error. I don't if this is any help.
Hi there,
I've a wounded Arcam Alpha Plus at home, skipping all the time.
Lens & laser cleaned, bottom steel ball cleaned and a bit lubed, the same.
Wich test points are the holes for the 50mV? Another adjustment?
That's a funny Philips PCB with a lovely Arcam DAC board
Matthieu
Matthieu
- Digital Source
- Arcam alpha plus cd player help
