free bb
You can get burr-brown chips for free.
Here is how:
Go to bb's site (texas instruments) and register for their 'samples program'. Then you search the chips that you want. Now you can click 'order samples' and order up to 2 chips of one type. You can order a total of 8 chips for free.
There are nothing suspect by doing this. They actualy give the chips away for free AND send them anywhere in the world without charge.
I have ordered DIR1701, PCM1742, DF1704 and PCM1702 and they arrived 3 days later by UPS (I live in Denmark).
The only 'drawback' is that they are SMD components.
Here is how:
SMD stands for Surface Mount. So, you don't drill holes for the pins like normal hole-thru components. Also, they are rather small and therefore hard to solder.
I suggest you try some of the SMD soldering links listed at epanorama.net.
http://www.epanorama.net/basics.html#soldering
Btw: Analog Devices also have a good samples program.
Thomas said:SMD stands for Surface Mount.
Surface Mount Devices - just to be pedantic
