Anyone try a DVC sub on a 2ch TPA3255?
Hello I have a DVC subwoofer that has 2.6ohm coils and have been searching for some cheap chip amps that could power it. I'm not looking to spend a lot on it because it's just an extra sub for my garage. It it were a dual 4 ohm sub it would make life much easier but I'm trying to work with what I have. Would it be possible to use an amp like the Aiyima A07 and hook 1 voice coil to each channel? I know it's below the recommended ohms but would it work if I used a lower voltage power supply with more amps? I have a SMPS that is adjustable from 1v-48v with 10amps.
